climate control prob.
Old Nov 7, 2003 | 02:59 PM
Vp Special K's Avatar
Default climate control prob.
Ok, i took out my dash in my 94 accord ex. When i put the dash back in, my fan (a/c, heater) only works on full bast (number 4). When the climate control is set to numbers 1,2 & 3 air DOESN'T comes out of the vents. However, air does come out of the vents when the dial is set to number 4. My a/c and heater works, but only when the dial is set to 4 (full blast).
Old Nov 7, 2003 | 05:39 PM
Default Re: climate control prob. (Vp Special K)
some1 has to know whats wrong
Old Nov 7, 2003 | 05:50 PM
89_LXi's Avatar
Just about anytime a fan only works on the 'high' setting is because of a problem with the resistor packs for the blower motor. Speeds 1 through 3 use 3 staggered resistors in series to control speed (3 resistors for 1 speed, 2 resistors for 2 speed, 1 resistor for 3 speed). When it's switched to HIGH, it bypasses all the resistors and the blower runs straight off +12v battery voltage.
Check around the blower motor for a disconnected plug somewhere in the area, which would be the resistor pack (usually right on the blower assy box itself)
Old Dec 10, 2004 | 10:19 AM
sweenmeat's Avatar
Vp Special K-
I have a similar problem with my 02 accord EX, except only 3 and 4 work on the fan. Was your problem the resistor pack or did it end up being something different? Was it an easy fix or did you have to rip the dash out again?
Old Dec 10, 2004 | 12:25 PM
95accordh22a's Avatar
Default Re: climate control prob. (sweenmeat)
mine did the same thing after i took the dash out in my 95, only worked full blast and to the defrost vents.... never found out y, doing h22 swap as we speak and i bought a parts car so i replace the whole heater box, hopefull stuff works better this time around
_EF9
Jul 29, 2013 05:37 PM
civisedan
Aug 31, 2011 11:45 AM
Dbach
10
Nov 11, 2008 06:28 AM
rwcdrums
Feb 2, 2003 12:52 AM
