Diff. in d15 w/mpfi and d16??? help
Old Nov 7, 2003 | 02:15 PM
RicedREX's Avatar
Default Diff. in d15 w/mpfi and d16??? help
ok I need to make a decision quick please help in anyway. I have a d15 with over 200k miles but runs very strong and dosent smoke. Ive been offerd a d16 from a crx si for $250, and in my search to make the swap complete I found a local MPFI set-up for $200, it has everything includoing a pm6...now my question is, is it even worth it to put the d16 in which has 150k miles and "worn seals" or should I just put the MPFI in, dosent it make it almost the same engine? I need to know quick cuz if a d15 with MPFI is close enough power wise then im just gonna do that.
Old Nov 7, 2003 | 02:40 PM
Escabar's Avatar
up to you mang,.
Old Nov 7, 2003 | 05:56 PM
RicedREX's Avatar
Default Re: (Escabar)
ok...
Old Nov 7, 2003 | 10:44 PM
Todd00's Avatar
I said I don't want a title!
Default Re: Diff. in d15 w/mpfi and d16??? help (RicedREX)
I have personally never seen a dyno of a MPFI equipped Dx motor, and I'd love to. Everyone says they are close, but the butt dyno usually sucks IMO. Maybe someone has one.
Old Nov 8, 2003 | 07:26 AM
Mrock's Avatar
Default Re: Diff. in d15 w/mpfi and d16??? help (Todd00)
I need to go to MPFI with my DX motor soon...(then go to the d16a6 swap). Maybe after I go to MPFI I will have it dyoned, to see...
Old Nov 8, 2003 | 07:39 AM
kylefakesi-r's Avatar
Default Re: Diff. in d15 w/mpfi and d16??? help (Mrock)
there is like a 3hp difference between the mpfi on a d16 block and head over the d15 block/head.
unless it is the hf block and head...then you should just swap the whole motor
driftam1
Mar 28, 2008 11:55 AM
slow_rex_will
Jul 29, 2006 07:40 PM
J.P.
Feb 6, 2006 05:14 PM
BadAndyGoodPizza
24
Oct 30, 2003 04:10 PM
hfracer420
Feb 12, 2002 07:54 AM
