About to put VTEC head on the y7, but.....
Old Nov 7, 2003 | 01:28 PM
Civiclx's Avatar
Default About to put VTEC head on the y7, but.....
I am about to put the y8 head on the y7 but I am concerned about one thing. two of the valves are sticking out about 3 cm past the other ones. Is this normal?
Modified by Civiclx at 5:58 PM 11/7/2003
Old Nov 7, 2003 | 01:57 PM
Civiclx's Avatar
Default Re: About to put VTEC head on the y7, but..... (Civiclx)
n e one?
Old Nov 7, 2003 | 02:02 PM
WangChung's Avatar
sticking out of the block?
Old Nov 7, 2003 | 02:58 PM
Civiclx's Avatar
Default Re: About to put VTEC head on the y7, but..... (97civhatch)
**** my bad, i meant valves, lol 2 valves sticking out of the head
Old Nov 7, 2003 | 04:09 PM
sleepN's Avatar
Out of the Combustion chamber or the top where the springs and rockers are. Either way you have a problem. If it's out of the combustion side you have a bent valve whic is not seating all the way. If it's out of the top you have the wrong valves. But definitely not good.
Old Nov 7, 2003 | 04:22 PM
Civiclx's Avatar
Default Re: (sleepN)
its right by the squelch (c. chamber) ill take pics, they may be bent, thanks for the help
Old Nov 7, 2003 | 04:47 PM
dsadas89das78934's Avatar
is the cam still in the head? there is no cam position which will allow all 16 valves to sit flush in the combustion chamber... there will always be valves sticking out.
Old Nov 7, 2003 | 04:58 PM
Civiclx's Avatar
Default Re: (soccaian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soccaian &raquo;</TD></TR><TR><TD CLASS="quote">is the cam still in the head? there is no cam position which will allow all 16 valves to sit flush in the combustion chamber... there will always be valves sticking out.</TD></TR></TABLE>
thanks bro, thats what i needed to hear, cause the cam is still in there
Old Nov 7, 2003 | 05:23 PM
yeah, it's cool... i'm also working on my mini-me... this is what i'm doin:
y7 block
d16a6 pistons and rods
ARP rod bolts
y8 head
ZEX titanium valve springs
Crower 53900 cam (stage 2)
and your usual bolt-ons...
its almost ready to be assembled..
Old Nov 7, 2003 | 10:07 PM
Civiclx's Avatar
sounds good, i plan to minime greddy turbo my hatch
Old Nov 7, 2003 | 10:12 PM
SOHC_MShue's Avatar
Default Re: (Civiclx)
props on building the d
xwhitchx
Mar 26, 2009 02:17 PM
one-cam
Jul 6, 2008 10:00 AM
remoer
Dec 6, 2007 06:22 AM
jaxle
Oct 8, 2003 09:48 AM
