Team DeltaDreams Honda Civic 4G63T project
Old Nov 7, 2003 | 11:10 AM
TSI_Xtreme's Avatar
Default Team DeltaDreams Honda Civic 4G63T project
For those that tried to view the project but couldn't because of my site, it has been upgraded now so you can see the project.
http://www.keenelandcars.012webpages.com
Things to come to the site:
Personal Car pages
Car Race Events
Car Shows
More on Team DeltaDream's 4G63T civic.
Danny
Old Nov 7, 2003 | 11:50 AM
poison's Avatar
Default Re: Team DeltaDreams Honda Civic 4G63T project (TSI_Xtreme)
That is one wack driver side mount. Doesn't look sturdy at all.
What was done for axles?
Old Nov 7, 2003 | 12:08 PM
Turbogixxer's Avatar
Default Re: Team DeltaDreams Honda Civic 4G63T project (poison)
Yes, I would like to know what axles you are using. And, you are using the Stock 4g63 timing belt motor mount, did it sit level?
Old Nov 7, 2003 | 01:22 PM
TSI_Xtreme's Avatar
Default Re: Team DeltaDreams Honda Civic 4G63T project (turbogixxer)
The axles are going to need to be custom made. I think that I'm going to have them made at "The Driveshaft shop". I have both the civic axles and the dsm's so what i'm going to do cut and weld them to fit and then after they fit properly I will send the off to "The Driveshaft shop" and have them reproduce them so they will be able to hold at least 400hp, hopefully more.
yes, its level.
Old Nov 7, 2003 | 01:42 PM
junglerunna's Avatar
Thats pretty crazy, but is the point of putting that motor in a civic? What are the specs on it?
Old Nov 7, 2003 | 03:23 PM
TSI_Xtreme's Avatar
Default The specs
the specs on a stock 4G63T? the stock numbers 210hp@235ft/lbs. The reason for this swap is simple for cheap quick horse power. You can spend less than 3,000 dollars the engine and push 400 horses. True many would worry about the dependablility of a DSM engine however this is a drag car. Many would say that a DSM engines have crankwalk, however 6bolt 4g63 engines do not have crankwalk issues like the 7 bolt engines some cases have occured but none like 7bolt engines.
Old Nov 7, 2003 | 04:38 PM
Six2Six's Avatar
It looks like Macguyver put it together to make a hasty get away from the drug smugglers
SP GARAGE
Jul 20, 2008 09:52 AM
NciroM2003
Sep 25, 2005 07:19 AM
eL
Jan 15, 2005 08:20 AM
