195/55/15
Old Nov 7, 2003 | 11:09 AM
DIYaccord's Avatar
Default 195/55/15
will this tire size work for my steelies on my 94 accord (they're 1996 accord's 15" steelies)...i know the speedo will be slightly off, but i can get them for really cheap.
Old Nov 7, 2003 | 11:29 AM
MAFA's Avatar
Default Re: 195/55/15 (DIYaccord)
if they are 4 X 114, yeah.
Old Nov 7, 2003 | 12:42 PM
TouringAccord's Avatar
H-T Order of Merit
Default Re: 195/55/15 (MAFA)
he's asking if a tire with a size of 195/55/15 will fit his steelies from a 96 Accord, not the rims.
So to answer your question, yes they will fit. You are correct on the speedo but you probably won't notice.
Old Nov 7, 2003 | 01:04 PM
KGAccord's Avatar
Default Re: 195/55/15 (TouringAccord)
i wouldn't use them, reason being they are used on civics and tegs which wiegh less than accords. the load rating is probably not high enouh for an accord. also that is smaller tire and the wheel gap will look bad.
Old Nov 7, 2003 | 01:33 PM
Accord94DX's Avatar
Default Re: 195/55/15 (KGAccord)
they work fine. I used ITR tires on my car for a road race season.
Old Nov 7, 2003 | 05:00 PM
sleepN's Avatar
the only thing you may not like is the ride quality. If you have it lowered already I guess you wouldn't mind.
Old Nov 7, 2003 | 09:40 PM
DIYaccord's Avatar
yup, its lowered and i just need some tires to use...
thank you guys
Old Nov 8, 2003 | 09:54 PM
HAccord96's Avatar
Default Re: (DIYaccord)
Stock 94-97 Accords run 195/60/15 so the tires that you are talking about won't mess up your gear ratios that much. The thing is, using tires that are smaller in circumfrence than the OEM makes the motor and tranny work harder, but I don't think it's much different from the stock tire profile to cause any problems.
Old Nov 10, 2003 | 03:22 AM
KGAccord's Avatar
Default Re: (HAccord96)
http://www.miata.net/garage/tirecalc.html
^use this it's a much smaller tire.
i don't see why you would want it, it still is 195 width a 205 50 15 is a better choice hence why teg/civic guys you that size.
accord 2005
Nov 8, 2011 06:27 PM
flyboymike
12
May 21, 2004 11:50 PM
chotchkie
Mar 30, 2004 07:09 AM
MAFA
Feb 18, 2004 07:29 AM
dynamo
Oct 19, 2002 03:23 PM
