Will "DA" integra FRONT calipers and rotors fit on '89 crx si.....
Old Nov 7, 2003 | 09:43 AM
litlekikr's Avatar
Default Will "DA" integra FRONT calipers and rotors fit on '89 crx si.....
Will "DA" integra FRONT calipers and rotors fit on 89 crx si?
if they fit then it should be a cheap brake upgrade, right? granted not a big diff. but enough to make a diff. I tried search and could only find stuff on the rears.
is this a direct swap? Will i run into porportioning (sp?) problems? is it even worth doing for 25 bucks?
Old Nov 7, 2003 | 09:44 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: Will "DA" integra FRONT calipers and rotors fit on '89 crx si..... (litlekikr)
search for integra knuckles
Stan
Old Nov 7, 2003 | 10:25 AM
JCracer723's Avatar
Default Re: Will "DA" integra FRONT calipers and rotors fit on '89 crx si..... (90crxsi)
use your stock lower and uper control arms and you should be fine
Old Nov 7, 2003 | 10:30 AM
4drEF's Avatar
Keyboard Humorist
No. You will need the knuckles too.
Old Nov 7, 2003 | 12:21 PM
EL Vap133's Avatar
Default Re: Will "DA" integra FRONT calipers and rotors fit on '89 crx si..... (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">No. You will need the knuckles too. </TD></TR></TABLE>
Old Nov 7, 2003 | 12:52 PM
egchan's Avatar
the rotors will fit, but the calipers won't reach. you need the knuckles like 4drEF said. a crx si mc is great upgrade, too.
Old Nov 7, 2003 | 12:59 PM
EL Vap133's Avatar
Default Re: Will "DA" integra FRONT calipers and rotors fit on '89 crx si..... (SlickCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlickCRX &raquo;</TD></TR><TR><TD CLASS="quote">a crx si mc is great upgrade, too.</TD></TR></TABLE>
He already has a CRX si.....
Old Nov 7, 2003 | 01:11 PM
egchan's Avatar
Default Re: Will "DA" integra FRONT calipers and rotors fit on '89 crx si..... (EL Vap133)
my bad, good point.
Old Nov 7, 2003 | 07:39 PM
Alan Wil's Avatar
4drEF
Could you go into more detail?
Does Caster, Camber, Toe, SAI . (Steering Axis Inclination.). and Roll center heights stay within useable parameters?
How much is roll center height altered by the increased height of the Integra knuckles?
Please post info and your cars alignment setting specs in this thread.
BIG Brake upgrade, Will 91 Integra Knuckles fit a 90 DX lowered 2 inches?
https://honda-tech.com/zerothread?id=668258
Old Nov 7, 2003 | 09:06 PM
Ef Whore's Avatar
Default Re: Will "DA" integra FRONT calipers and rotors fit on '89 crx si..... (JCracer723)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCracer723 &raquo;</TD></TR><TR><TD CLASS="quote">use your stock lower and uper control arms and you should be fine </TD></TR></TABLE>
Knuckles will be needed as well....
Old Nov 7, 2003 | 09:11 PM
Ef Whore's Avatar
Default Re: Will "DA" integra FRONT calipers and rotors fit on '89 crx si..... (Alan Wil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alan Wil &raquo;</TD></TR><TR><TD CLASS="quote">4drEF
Some people use teg knuckles and supposedly have no probs....the JDM Xsi knuckles I installed on a fellow H-Ters car(91STD, complete XSI VTEC swap) gave the front end slight positive camber and a little toe-in at stock height. But some 2" springs will fix the camber(will leave it around -.5), then simply set your L/R toes to zero and you are ready to roll.
Old Nov 17, 2003 | 07:24 PM
Alan Wil's Avatar
Default Re: Will "DA" integra FRONT calipers and rotors fit on '89 crx si..... (Ef *****)
Thanks for the info.
If you run accross any more info please post it in the thread mentioned above.
I'm concerned with the changes made to roll center heights, roll axis, camber change during cornering as some have said the Integra steering kunckles are "taller" than the Civic parts. If so this would change the parameters of the above items.
Thanks again for the info, and keep me in mind if you run accross anything.
teler86
Suspension & Brakes
Jan 10, 2007 10:20 PM
BorderM3
20
Jul 20, 2005 02:56 PM
Cowiebunga
May 26, 2005 05:09 PM
No
Apr 21, 2004 03:53 AM
Gonzo_SiR
Mar 10, 2004 06:55 PM
