Rebuilding a JDM H22. What all should I change??
Old Nov 7, 2003 | 05:59 AM
AndyD's Avatar
Default Rebuilding a JDM H22. What all should I change??
Well, I am rebuilding a JDM H22. I was wondering what all I should replace on it??
The guy rebuilding it wants me to bring him all the parts. I was thinking replacing the water pump, timing belt, piston rings, rod and crank bearings. I am replacing only with oem parts.
What else should I do while it is apart?? Should i have the pistons treated/machined??
Where is the best place to buy the parts???
Also, how do I get the block to look new again??? Might as well touch it up while it is out.
Thanks
Old Nov 7, 2003 | 07:36 AM
CHK4TIX's Avatar
Default Re: Rebuilding a JDM H22. What all should I change?? (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">Well, I am rebuilding a JDM H22. I was wondering what all I should replace on it??
Thanks
sounds like you got most of it covered, unless you can find some type-s pistons to throw in there. As far as prices for oem stuff the cheapest place i have found it http://www.hparts.com if you know the part numbers. If you have a helms you should just rebuild it yourself, its really quite easy to do. Also while your at it you might as well swap out the auto tensioner to manual
Old Nov 7, 2003 | 02:44 PM
LudeyKrus's Avatar
- All belts
- Pistons
- Rods
- Rings
- Head Gasket and seals (esp. valve seals)
- Rod and Main Bearings
- Thrust Bearing
- Crank Seals
Maybe a few other things, but that's the jist of it for now.
A few things really depend on the mileage of the motor; if it was quoted at about 30k, say it was 60-70k. The pistons and rods may not NEED to be replaced, but if I were building this thing to hold any decent amount of HP, then I'd replace them anyways just to make sure I know EXACTLY what all went into the motor.
Old Nov 7, 2003 | 07:24 PM
ApexiAccord's Avatar
Default Re: (LudeyKrus)
timing belt, balancer belt. auto tensioner
water pump
oil pump
HG
all new OEM bearings
all new gaskets
spark plugs and wires. cap and rotor
new pistons and rings but check to see if need to overbore incase of scars on the walls
resurfaced flywheel
clutch mite as well since the motor is out
all fluids
anything else i forgot?
Old Nov 7, 2003 | 07:41 PM
satan_srv's Avatar
Default Re: (ApexiAccord)
oil pump
manual tensioner conversion
type-s pistons
climb_on
10
Aug 15, 2007 04:36 PM
climb_on
Aug 14, 2007 08:19 AM
DarKStaR5
Jan 29, 2007 07:19 PM
djnikko
Nov 9, 2005 03:24 AM
