toda cams
Old Nov 7, 2003 | 12:05 AM
b18jdmteg's Avatar
Default toda cams
anyone running the toda spec b's i would like to know the lift and duration on these cams , and if am going to have any kind of valve clearance problems i am running a b18c1 block with usdm itr pistons mugen head gasket , itr head , and hopefully toda spec b's if their is no clearence issues, your help with my problem is greatley appreciated
Old Nov 7, 2003 | 05:55 AM
Fobtions's Avatar
Default Re: toda cams (b18jdmteg)
you probably wont have any problems, ive seen people with bigger cams and higher domed pistons with that gasket. good luck. just make sure everything is put together right.
Old Nov 7, 2003 | 07:01 AM
Tweakmeister's Avatar
http://www.akhtrading.com has your info.
for clearance...safest bet is to clay the motor
Old Nov 7, 2003 | 07:52 AM
VTECisSeXY's Avatar
*insert here*
Default Re: toda cams (Tweakmeister)
way off topic, but I love florence's water tower off of I-71. FLORENCE YA'LL!
Old Nov 7, 2003 | 08:39 AM
Ketone's Avatar
Default Re: toda cams (VTECisSeXY)
http://www.allmotorhonda.com/t...s.htm there you go for cam specs, and some more for flavor. I don't think you should have clearance issues, but as tweak says, you should clay the motor to be sure
Old Nov 7, 2003 | 10:06 AM
b18jdmteg's Avatar
thanks for the info guys i'll check these sites out on the lift and duration of these cams
N1 Andy
30
Jan 16, 2009 11:03 AM
luis666
Mar 21, 2006 09:07 AM
boostin4door
Apr 5, 2004 08:40 PM
MCP486
May 1, 2003 07:12 PM
K20 EG
Apr 25, 2003 09:51 AM
