code 14...then a new eacv..and still code 14 WTF!!!
i had code 14 this is on a d15b2 completely stock
i just installed a new eacv which fixed my erratic idle and everything but i'm still throwing code14...i pulled my hazard fuse and let my car sit with battery disconnected for about 30 min
wtf!!!
wtf!!!
Check the IAT sensor...I heard that it also can cause a code 14, but i could be wrong....woundn't hurt to try. also check and make sure none of the wires are cut or melted.
take plug off the sensor
and take harness off ecu
make sure u go and check is theres resistance from plug to harness inside
use a ohmeter
im not sure what terminals since i am at work.
but thats the way to find out if u have a fracture on the elecrtric wiring somwhere
wiggle the wirin while testing
use a ohmeter
