motor swap
the d15 injection system is by far the worst part of a d15!! yes it will bolt up to a d16 and run, but your car will NOT be any faster!! If you're doing this because your engine is blown and you have a d16 lying around and you're not interested in performance, then yes, it will work. and yes, ANY D16 would work. (just don't engage VTEC with that bottleneck of an intake mani.
If you're engine is in decent shape, and you're looking to improve performance, do an MPFI swap, an si cam, and an Si tranny. these 3 items are what make the Si faster than the DX or STD
if you want to perform this swap i got everything you need beside engine!!!
i got a Converted engine wiring harness, fuel line, ECU!!!!!!!!
let me know FREDERZ@aol.com
