no pull at all in 1st gear/ d16a6 turbo
Old Nov 6, 2003 | 09:06 PM
sxecustoms's Avatar
Default no pull at all in 1st gear/ d16a6 turbo
Just wondering if anyone else has the same problem... In 1st gear, the car barely wants to move, not to mention the gear is super short. Any thing to worry about or is it just econo gearing of a d16?
Old Nov 6, 2003 | 09:33 PM
goofball123321's Avatar
Default Re: no pull at all in 1st gear/ d16a6 turbo (sxecustoms)
the car dosn't want to move in first at all? or the car doesn't wanna boost in first?
Old Nov 7, 2003 | 01:21 AM
MustangPunk302's Avatar
You know what the ratio is? It is probably geared pretty high (numerically lower) for enco reasons, but you said it was short which would make it actually a lower ratio (numerically higher). How short is it?(i.e. you redline only going 10 mph? Ole Ford Pickup stylee) lol Does the clutch engage fine?
Old Nov 9, 2003 | 12:20 PM
sxecustoms's Avatar
Not sure of the gearing but its not short as in RPMS, short as in no power... Maybe i worded it wrong. It tends to bog down after about 10 mph but does not redline. And yeah the clutch engages just fine in first.
Old Nov 9, 2003 | 06:25 PM
xlr8civic's Avatar
are you getting enough fuel? my friends zc hatch had a problem like that and it would run really lean on stock injectors and fuel pump. if your not than i don't know just trying to tell ya what happened to my buddys car
Old Nov 9, 2003 | 06:34 PM
brent_G's Avatar
Default Re: (xlr8civic)
it prolly just rips through the rpms soo fast doesnt really seem like its doin anything. I had 8psi on my a6 with si tranny and i couldnt really get traction at all in first. And would hit rev limit almost instantly.
Old Nov 10, 2003 | 11:05 AM
sxecustoms's Avatar
Im running a 14B w/ the stock d16a6
Vortech 12:1 FMU for fuel
upwards of 6 or 7 psi
I dont think that would be the problem cause the TDO5H is a super small turbo, perfect the motor. But thanks for the sugggestion.
Old Nov 10, 2003 | 01:31 PM
89s1's Avatar
Default Re: (sxecustoms)
i'll agree with the group. it is likely the close ratio tranny killing it.
its always hard to build up to full boost in 1st gear... ALWAYS
i'm the mechanic for a supra and it is literally fster in 2nd and 3rd then it is in first when he runs anything over stock boost.
he'll never see anything over 10psi in 1st gear.
2nd gear it boosts like a ************
the best was one time running 15psi and having a vacuum hose get blown right off the intake manifold
Spinks
Honda Civic (2006 - 2015)
Nov 23, 2010 06:01 PM
unknownally
Transmission & Drivetrain
11
Jul 24, 2010 03:20 AM
92 civic VX B18c
Oct 6, 2003 10:14 PM
Toms96GSR
Jul 29, 2002 01:36 PM
tensai
Oct 26, 2001 10:40 PM
