retainers for toda b's, daily driven
Old Nov 6, 2003 | 08:29 PM
redzcstandardhatch's Avatar
something different
Default retainers for toda b's, daily driven
the head will be fully worked over with toda dual spring valvesprings and toda b's, compression will be raised slightly, and the motor is a jdm itr motor, going into a 00' si, will titanium retainers hold up to fairly regular driving/lots o' track days at gingerman? just curious.
Old Nov 7, 2003 | 07:34 AM
NSX Bob's Avatar
New User
Default Re: retainers for toda b's, daily driven (redzcstandardhatch)
IMO, sure, as long as they are installed right. Works for me in my motor (knock on wood).
Old Nov 9, 2003 | 07:02 PM
something different
Default Re: retainers for toda b's, daily driven (Type R Bob)
ive read they wear out sooner, any other experience?
Old Nov 9, 2003 | 07:31 PM
len's Avatar
len
I run stock retainers on my car.
Old Nov 9, 2003 | 09:35 PM
strepto's Avatar
Default Re: retainers for toda b's, daily driven (len)
What kind of retainers are optimal what B's and C's, or stage 2/3 cams? I mean - there are sooo many to choose from, and some say stocks are fine, some say they arent.
Portflow, Crower, Ferrea, JUN... what to get?
I'd rather spend 100usd extra on a good set of retainers, rather then having my valvetrain blown to bits by a a cam havin a bad day.
Old Nov 10, 2003 | 08:01 AM
Rob Dizzle's Avatar
Default Re: retainers for toda b's, daily driven (strepto)
imho, the whole ti retainer breakage thing is more of a h-t urban legend
yes ti retainers can wear more, but if the retainer is designed properly and isnt loosely fit. then there shouldnt be any problems
if you are running toda b's and will be revving pretty high. you will want to check your valve lash every 5k, you might as well get a lil mirror and look at the thickness of the ti retainers.
that way you can tell if one is wearing too thin or not.
or you can look into the ib spec Al. retainers. similar weight saving but less chance of it galling or breaking
if you are running stock valves, then stock retainers usaully will work fine
Old Nov 10, 2003 | 12:03 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: retainers for toda b's, daily driven (Bob-DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">
Where can you find more info on these?
Old Nov 10, 2003 | 12:22 PM
Rob Dizzle's Avatar
Default Re: retainers for toda b's, daily driven (FrostyDC4)
https://honda-tech.com/zerothread?id=670750
import builders are good people
jt-sport
24
Jun 14, 2007 06:15 AM
gakkuken
18
Dec 14, 2004 10:46 PM
b19coupe
17
Oct 6, 2003 10:48 AM
J2turbo21
Jul 25, 2003 06:56 PM
Chugger
Nov 15, 2002 07:04 PM
