squecky noise
Old Nov 6, 2003 | 08:09 PM
ggangtong81's Avatar
Default squecky noise
when i step on the clutch, it make this squecky noise. do i need to replace the
clutch cable?? or does it just need some grease?? any suggestion of how to fix it??
Old Nov 6, 2003 | 08:10 PM
Mikizzle's Avatar
yes i would like to know this too
Old Nov 6, 2003 | 08:38 PM
LSTEG96's Avatar
Default Re: squecky noise (ggangtong81)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ggangtong81 &raquo;</TD></TR><TR><TD CLASS="quote">when i step on the clutch, it make this squecky noise. do i need to replace the
clutch cable?? or does it just need some grease?? any suggestion of how to fix it??</TD></TR></TABLE>
this may be ur first problem
Old Nov 6, 2003 | 08:45 PM
Sukebei Oni's Avatar
have someone try to isolate the squeek while you step on the clutch. find where its coming from and then see if greasing it helps. i'm geussing most of the noise happens when the car is cold. since things tend to be more sticky when cold, after they warm up they loosed a little. check the clutch fork.
Old Nov 7, 2003 | 04:08 AM
JimBlake's Avatar
Default Re: squecky noise (Sukebei Oni)
Cable or clutch fork should squeak about the same with the engine running or not running.
If the engine needs to run in order to make the noise, look at throw-out bearing or pilot bearing or something that only spins with the engine running.
Old Nov 7, 2003 | 02:34 PM
Blk95GSR's Avatar
Default Re: squecky noise (JimBlake)
mine is making a squeek too, it happens even if the car is bone cold off. I was thinking it was my declining master cylinder?
Old Nov 10, 2003 | 03:28 AM
JimBlake's Avatar
Default Re: squecky noise (Blk95GSR)
Listen while someone works the clutch. Find the exact location of the sound.
ej6kid
Sep 30, 2010 01:15 PM
NOahFATCHICS
Oct 20, 2004 04:20 AM
The Internet Tough Guy
Sep 26, 2003 09:06 PM
VR6T
Feb 6, 2003 02:08 AM
