sluggish?
Old Nov 6, 2003 | 06:16 PM
HatchBox's Avatar
Skoobie no more...
Default sluggish?
Alright guys my friend needs your help,
Alright well my friend did a b16 swap in his 91 civic hatch. Everything went ok, but he got it running and he got it from the shop, they had to switch the knuckles. anyways he had put tranny fluid in the back of the car with the knuckels...so he got the car and we drive it from the shop and its really really sluggish, like its slower then my Std. and we go about mile and a half and the check engine light comes on and all of a sudden 3rd wont work, and its supper sluggish...like crawling....did the mecanics forget to put the tranny fluid in? cuz the bottles were full when he got the car back. but they might have used there own. What else could it be? In third its really bad like it makes a grinding/not catching kind on noise...oh he has a 8.8 flywheel and a action clutch...how would we go about checking the level of tranny fluid?
any help would greatly be appriceiated.
oh, we turned the car off and it throws a code 1 now...
Old Nov 7, 2003 | 09:51 AM
Donkey85's Avatar
Default Re: sluggish? (ind3ciso)
by what you are saying it alsom make me believe that they didnt put fluid back into the trans. you shouldn't have a grinding problem like that. is that a new tranny that you got with youe swap or an old one that you had? i ask that becasue maybe it is a bad trans from the start
Old Nov 7, 2003 | 01:35 PM
HatchBox's Avatar
Skoobie no more...
Default Re: sluggish? (Donkey85)
update. well the garage didnt put fluid in it...so i was driving 2 miles with no tranny fluid great so now i probally have some fucked up syncro's
Old Nov 7, 2003 | 02:50 PM
HatchBox's Avatar
Skoobie no more...
Alright guys well he put in honda mtf and he still said its sluggish...maybe the compression is bad? idk . its not throwing anycodes he says and 4th and 5th shake the car...like vibrate. is this the clutch and flywheel?
Old Nov 7, 2003 | 04:12 PM
ThatRicerDaniel's Avatar
when you say sluggish can you be a little more descriptive.. does it feel like a lawnmower or does it feel worse? is vtec activating?
Old Nov 7, 2003 | 04:20 PM
HatchBox's Avatar
Skoobie no more...
Default Re: sluggish? (NitrousDreamz)
well its like not pulling hard at all...i really cant tell if v-tec is engaging i didnt bring it up that high.
Old Nov 7, 2003 | 05:19 PM
HatchBox's Avatar
Skoobie no more...
Old Nov 7, 2003 | 05:43 PM
Speedyjay's Avatar
4th and 5th are usually the first to go on a worn tranny since they receive the most stress, but USUALLY 4 miles wont kill a tranny like that (least it didnt on mine on my first engine swap)
Does the car stay in gear in 4th and 5th?
Old Nov 7, 2003 | 05:56 PM
HatchBox's Avatar
Skoobie no more...
Default Re: sluggish? (Speedyjay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedyjay &raquo;</TD></TR><TR><TD CLASS="quote">Does the car stay in gear in 4th and 5th? </TD></TR></TABLE>
yep stay in gear fine....would the flywheel and cluch not be worn enough yet or something?
Old Nov 7, 2003 | 09:49 PM
Donkey85's Avatar
what i would do is take another spare trans if you have one around and out it on and see how it acts with that. if it works fine then you know it was the trans that was bad. after the new one is on and the car still acts the same then you know its your motor ******* up
Old Nov 8, 2003 | 04:32 AM
HatchBox's Avatar
Skoobie no more...
dont have a spare transmission...
Old Nov 8, 2003 | 08:40 AM
89Si's Avatar
i'd drive it a little bit and see how the clutch settles in. sometimes it takes a few hundred miles for the clutch to work properly. depending on the clutch manufacturer and transmission, it might need break-in time. mine sucked at first in a few gears, but then it softened up. then i got a motor swap and now everything sucks but thats a different story. but before you check out the actual engine performance, rule out the possibility of a bad trans. maybe adjust the clutch a little?
Old Nov 8, 2003 | 02:07 PM
HatchBox's Avatar
Skoobie no more...
Default Re: sluggish? (89Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89Si &raquo;</TD></TR><TR><TD CLASS="quote">i'd drive it a little bit and see how the clutch settles in. sometimes it takes a few hundred miles for the clutch to work properly. depending on the clutch manufacturer and transmission, it might need break-in time. mine sucked at first in a few gears, but then it softened up. then i got a motor swap and now everything sucks but thats a different story. but before you check out the actual engine performance, rule out the possibility of a bad trans. maybe adjust the clutch a little?</TD></TR></TABLE>
so the trans is probally good right...it seems to shift fine...so i dont think the snycros are that bad...
Old Nov 8, 2003 | 02:56 PM
mntuner2's Avatar
OK, its probably not your transmission since it goes and stays into gear. How are the engine oil and coolant levels?? Have you performed a tune-up on the motor since you purchased it?? A code 1 is the oxygen sensor. My car ran like crap when my o2 sensor was bad. Does it pull hard when it is warming up??
Old Nov 8, 2003 | 03:47 PM
HatchBox's Avatar
Skoobie no more...
Default Re: sluggish? (mntuner2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mntuner2 &raquo;</TD></TR><TR><TD CLASS="quote">OK, its probably not your transmission since it goes and stays into gear.</TD></TR></TABLE>
GOOD!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mntuner2 &raquo;</TD></TR><TR><TD CLASS="quote">How are the engine oil and coolant levels?? </TD></TR></TABLE>
Full
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mntuner2 &raquo;</TD></TR><TR><TD CLASS="quote">Have you performed a tune-up on the motor since you purchased it?? </TD></TR></TABLE>
i dont think my friend has done a tune up, other then timing belt, tensioner waterpump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mntuner2 &raquo;</TD></TR><TR><TD CLASS="quote">A code 1 is the oxygen sensor. My car ran like crap when my o2 sensor was bad.</TD></TR></TABLE>
he said since he put in tranny fluid in it. it hasnt thrown the code...so maybe it just got really hot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mntuner2 &raquo;</TD></TR><TR><TD CLASS="quote">Does it pull hard when it is warming up??</TD></TR></TABLE>
i will have to ask.
slow91integra
Nov 18, 2005 12:50 PM
P@@RB@Y
Sep 9, 2005 01:45 PM
95gsrturbo
Acura TL, RL & ZDX
Apr 9, 2005 09:07 PM
ice-burg-slimm
Feb 14, 2005 03:47 PM
mrnicolas
Oct 9, 2002 10:52 AM
