upping the redline
Old Nov 6, 2003 | 05:39 PM
slowww b18b1's Avatar
Default upping the redline
i have a question, i know to get a higher redline u should start workin on the valvetrain and jess basically gettin cams valves,springs, retainers, etc. but once u do all that exactly how do u know what ur car is able to redline at now????
Old Nov 6, 2003 | 05:43 PM
threatcon13's Avatar
New User
Default Re: upping the redline (B18B1-turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18B1-turbo &raquo;</TD></TR><TR><TD CLASS="quote">i have a question, i know to get a higher redline u should start workin on the valvetrain and jess basically gettin cams valves,springs, retainers, etc. but once u do all that exactly how do u know what ur car is able to redline at now????</TD></TR></TABLE> Usually when you get the cams, valvesprings, and retainers, (don't bother w/ the valves) the manufacturer will tell you what rpm they are safe up to. But best bet is to go on a dyno after you get everything in, tune it, and find out what rpm they are making power up to.
Old Nov 6, 2003 | 05:49 PM
Eviloliv3's Avatar
well your cams will be able to go to a higher rpm, but you might not want to run to 9k rpms all the time, since the LS has a crappy rod/stroke ratio. but the manufacturer should say what rpms you can take it up to, i know crower says "8500+", so i personally would know that i could take it up to 8000 safely. but it wouldnt do it in a LS. just my opinion
Steeve_Civic
Dec 13, 2013 01:57 PM
MI4$DC5
Apr 22, 2006 06:37 PM
jam05pr
Jun 6, 2005 09:31 AM
aznsins88
Nov 18, 2004 03:13 PM
2ndgent3g
Nov 4, 2004 02:06 PM
