Is there a difference between Ls and Gsr harnesses or is it plug and play
Old Nov 6, 2003 | 03:02 PM
SPLNRSX's Avatar
Default Is there a difference between Ls and Gsr harnesses or is it plug and play
I'm putting a Ls swap into my Gsr shell and was wondering if there is a differnce in these harnesses or if it's just plug and play.
Old Nov 6, 2003 | 03:12 PM
MooreBoost's Avatar
Default Re: Is there a difference between Ls and Gsr harnesses or is it plug and play (rsxswa)
The Ls wont have a knock sensor, or any of the VTEC stuff, so you will throw multiple codes. Just a guess but everything should plug in, youll just have to leave stuff hanging.
gmoore
Old Nov 6, 2003 | 03:21 PM
sohc it to me's Avatar
Default Re: Is there a difference between Ls and Gsr harnesses or is it plug and play (tegunderpressure)
yeah just leave whats not used unplugged, u wont throw codes because the ls ecu wont look for it.
the only thing is what year is ur gsr shell and what year is the ls motor
Old Nov 6, 2003 | 07:36 PM
SPLNRSX's Avatar
Default Re: Is there a difference between Ls and Gsr harnesses or is it plug and play (95blkgsr)
there both obd1 the shell is a 95 and the swap is a 94 hopefully it works out
Old Nov 6, 2003 | 08:35 PM
yeah it should work out, there will be plugs that arent used
Old Nov 6, 2003 | 11:30 PM
SPLNRSX's Avatar
cool I'll see how it goes thanks
NVturbo
Feb 27, 2007 05:38 PM
iiilgsrlll
Sep 18, 2003 10:02 AM
yellaboi
Sep 3, 2003 05:59 AM
Forgiven
Nov 10, 2002 11:13 PM
