question about injectors
Old Nov 6, 2003 | 02:15 PM
96dxB16's Avatar
Default question about injectors
ok, so here is the deal.
i have a 96 spec B18C spec R, when i pulled the head, i found toda 12.3:1 pistons. good find, but it sucks because i live in CA. so the best gas we have is 91 octane. i don't know much about injectors, but i have been told i should go with a 370 or 440 cc injector. is anyone out there running this type of compression in CA on 91? if so, what is your setup? what is the difference between peak/hold and saturated?
thanks
Old Nov 10, 2003 | 11:42 PM
G U E C O's Avatar
Default Re: question about injectors (96dxB16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96dxB16 &raquo;</TD></TR><TR><TD CLASS="quote">it sucks because i live in CA. </TD></TR></TABLE>
Old Nov 11, 2003 | 07:36 AM
TGUNNER's Avatar
Your going to need saturated injectors. 310's should be perfectly fine. Then get it tuned so you can run 91octane. Reatard that timing and get colder plugs to be on the safe side..
IP RACING
Apr 30, 2007 11:11 PM
STEEZY_EG+DC
Nov 3, 2006 12:10 PM
mingbling96
Jul 3, 2006 10:43 AM
crdcz03
Aug 8, 2004 05:21 PM
Sohc Driver
Jan 9, 2004 08:09 PM
