Ok, so here's my problem can you help?
Old Nov 6, 2003 | 09:20 AM
Opie's Avatar
Default Ok, having tranny troubles please give input!
Lately, (may be going on longer only noticed it recently) i've been noticing a distinct noise coming from inside my engine bay. It seems to be generally coming from my tranny.
It is a whine that does not go away when I press in the clutch or when im off it(don't think it is the TO bearing). It's always there. The noise varies depending on engine rev speed(possibly a fly wheel). and I can still hear it if I try to when the car is in motion.
Really hope this isn't what happened to Rob(Bbasso and his tranny woes)because i'm having a hard enough time paying for my car as it is and definately can't afford a tranny.
My clutch engagment seems to be the same as it always has been since I bought the car in June bone stock. My only mod is an AEM CAI.
Please help and don't confirm my fears
Thank you
Modified by opie112 at 1:50 PM 11/6/2003
Old Nov 6, 2003 | 10:42 AM
Opie's Avatar
Default Re: Ok, having tranny troubles please give input! (opie112)
Tizzle i need some hizzle!
Old Nov 6, 2003 | 10:46 AM
thk's Avatar
thk
Members Only
Well, if it's the same problem as Rob, don't do what he did. What I mean by that is still drive the damned thing into the ground despite the noise coming from the transmission.
PM Dan GSR on how much he would charge for the service. It'll probably be very reasonable.
Old Nov 6, 2003 | 10:53 AM
Opie's Avatar
Default Re: Ok, having tranny troubles please give input! (thk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thk &raquo;</TD></TR><TR><TD CLASS="quote">Well, if it's the same problem as Rob, don't do what he did. What I mean by that is still drive the damned thing into the ground despite the noise coming from the transmission.
PM Dan GSR on how much he would charge for the service. It'll probably be very reasonable.</TD></TR></TABLE>
What do you think it could be? Any ideas?
Old Nov 6, 2003 | 11:09 AM
thk's Avatar
thk
Members Only
Can't tell by reading your posts about it. Got to hear it in person.
Old Nov 6, 2003 | 11:31 AM
RTW DC2R's Avatar
did you check/change your tranny fl00id? Try GM Synchromesh and see if that smooths out the noises.
do you have any grinding or is it hard to get in and out of any gears?
mine makes noise too, but I dont know if its the motor or tranny. Sometimes it sounds almost like its supercharged because the whine is so prevalent.
I can probably have my mechanic take a look if you want, not sure how much he would charge you though. if you and some friends cant do it your self, it shouldnt cost too much to just drop the tranny and atleast take a look and maybe clean and l00b some parts to see if that helps.
Old Nov 6, 2003 | 11:36 AM
Opie's Avatar
Default Re: Ok, having tranny troubles please give input! (RTW DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">do you have any grinding or is it hard to get in and out of any gears?</TD></TR></TABLE>
No grinds just notchy feeling. Think it is normal though, its like that in my boys R.
Note. I don't know the last time the tranny fluid was flushed and changed..
Old Nov 6, 2003 | 11:44 AM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie112 &raquo;</TD></TR><TR><TD CLASS="quote">Note. I don't know the last time the tranny fluid was flushed and changed..</TD></TR></TABLE>
There's a start.
Don't forget to replace the tranny oil filter and use Genuine Honda MTL.
Old Nov 6, 2003 | 11:47 AM
Opie's Avatar
Default Re: Ok, having tranny troubles please give input! (zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">Don't forget to replace the tranny oil filter and use Genuine Honda MTL. </TD></TR></TABLE>
Bought the Honda MTL 3 weeks ago haven't had a chance to flush my tranny out. Weather has been shitty also and work is a nightmare
Old Nov 6, 2003 | 11:50 AM
Dan GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thk &raquo;</TD></TR><TR><TD CLASS="quote">Can't tell by reading your posts about it. Got to hear it in person.</TD></TR></TABLE>
squirt
Aug 12, 2007 08:35 AM
PreludePhill
Apr 23, 2007 05:08 PM
swatteamtimmah
Feb 8, 2006 03:39 PM
turbohf
Mar 17, 2003 01:24 AM
MCP486
Jan 14, 2003 04:25 PM
