SI tranny problems.
Old Nov 6, 2003 | 09:17 AM
Escabar's Avatar
Default SI tranny problems.
Ok now that my swap is in, d16a6 running good, this is my problem, car goes thru gears when engine is off but when its running wont go in to gear, now ive tried messing with the linkage and tried adjusting the clutch cable @ a bunch of different settings with still no luck, it lowers the rpms about 200-300 when i try putting it into gear, If i start the car in first gear with clutch in the car will jump forward... this has been my first swap in my first honda and im proud to say i got the engine running kool but damn the tranny wont go into gear.... I know this tranny worked since i drove the car home with the old d16a6 and went into gear fine. The clutch disc that came on the new engine looked thicker than the one that was on the old motor that got pulled so i just left it on the engine and assumed it would work....any suggestions would be appreciated.
Old Nov 6, 2003 | 10:27 AM
Escabar's Avatar
Default Re: SI tranny problems. (Escabar)
bump for help.
Old Nov 6, 2003 | 10:38 AM
kid-honda's Avatar
Make sure that is the right clutch and its not over tourqed, both of them problems have happened to a buddy and caused the same problem. Do you know forsure what car that clutch is for?
Old Nov 6, 2003 | 10:43 AM
Escabar's Avatar
came out of a 89 si
Old Nov 6, 2003 | 10:44 AM
virginia_dude's Avatar
dude your clutch is not fully disengaging you got problems there that need fixed, is your throwout bearing installed correctly? or did you put the clutchdisk on backwards binding things up and causing this?
Old Nov 6, 2003 | 10:55 AM
Escabar's Avatar
pulled tranny off old motor and swapped onto new motor that allready had flywheel and clutch on it.... the lever on the tranny moved the throw out bearing back and fourth when i moved it up and down sooo....... dunno
Old Nov 6, 2003 | 11:05 AM
Default Re: (Escabar)
well something is wrong with the pressure plate then if you didn't have the clutch off and managed to get the disk on backwards, and yes it matters which side is out. I say that because when you do get it in gear the RPM's drop about 300, the clutch should fiully disengage and there should be no drag on the motor, Something is wrong with that clutch. Assuming it was properly adjusted. THe drag is keeping the gears from messing and going into gear.
Old Nov 6, 2003 | 11:13 AM
Escabar's Avatar
what do you mean when u say i managed to get the disk on backwards? i never touched it just swapped the tranny on motor and put into car. and when the rpms lower 300 it doesent go into gear, its just when i try putting into gear, like im locked out....
Old Nov 6, 2003 | 11:16 AM
kid-honda's Avatar
Whats the history of the motor that the clutch came attached to? is your clutch cable streched?
Old Nov 6, 2003 | 11:18 AM
Well, then its defective. because it is not releasing fully. Whatever reaason you will be buying a new one. Nothing else can be responsible for it. if you adjusted all the slack save one inch movement at the clutch release arm then the clutch is at fault and not the adjustment. I can't see the cable stretching more than it ccan adjust for. He has something wrong the clutch is not fully releasing and he needs to find out how much slack he has at the transmission end of the cable. if he gets the slack adjusted out then he has a clutch problem. ANd it sounds like he already tried that.
Old Nov 6, 2003 | 11:19 AM
Escabar's Avatar
103k supposedly wasent driven hard pulled for b series swap. pretty sure clutch cable isent streched because i can make it tight or loose depending on how i adjust the cable.....
Old Nov 6, 2003 | 11:50 AM
well if he can adjust all the slack out and it still does it then it is certainly a bad clutch.
Old Nov 6, 2003 | 01:36 PM
Escabar's Avatar
where can i buy a good clutch for my application? somthen good to about 200hp
Old Nov 6, 2003 | 03:53 PM
USDM 4G VTEC's Avatar
u have a bad pressure plate
that happened to my buddy and one of the legs of the plate broke and feel into it making it ack like that
i say go to ebay and buy a EXEDY stage 1 organic from CLUTCHCITYONLINE
good to up to 200hp (65% over sstock)
they are 98+ship and they are great i ove then and have boiught 3 for me and friends
Old Nov 6, 2003 | 05:11 PM
lelopez's Avatar
Default Re:
Was the flywheel recently resurfaced? Let me know b/c if it was then I've got an answer for you.
Old Nov 6, 2003 | 10:24 PM
Escabar's Avatar
i dident touch the flywheel or remove the clutch so i dont know. started it up tonight and it sounds nice. now i just need to use the power, also what would be the best axels to go with the si tranny? thanks
Old Nov 7, 2003 | 04:12 AM
If you had a DX, stock axels are perfect, you need to tell us what model this car is first, if it was Si or DX keep what it came with.
Old Nov 7, 2003 | 07:21 AM
Escabar's Avatar
91 dx
Old Nov 7, 2003 | 07:28 AM
what you have already will be plug and play. With a Si Box
Old Nov 7, 2003 | 07:32 AM
Escabar's Avatar
i just want some axles that i know wont break down on me. dont ever wanna be on the side of the road changing an axle cause that sux.
Old Nov 7, 2003 | 08:05 AM
Si and DX axels are identical, no differences at all, as long as they aren't worn out.
Old Nov 7, 2003 | 09:33 AM
Escabar's Avatar
im trying to get some "performance axles" do they not make them for D series trannys? because i know you can buy them for B series.
Old Nov 7, 2003 | 09:49 AM
exactly how much HP do you expect that motor to make to make it worth the cost of performance axels, Just get remanufactued ones if you are worried about your existing ones, I have Trak Auto remanufactured ones on my car (I have '93 TEG axels) with my ZC box for 2 years now and I am making more HP than that motor is making with no troubles. And I love an occaisional holeshot, with tires smoking. Performance axels are going to cost you more than a performance clutch will and thats more likely to give you trouble than the axels will.
If you were sleeving the block beefing up the internals and planning to run 20+ lbs of boost, then maybe you would need to worry about perfomance axels in my mind.
oresama
Jul 29, 2018 08:46 PM
Mr.Shiftwell
Jun 27, 2013 10:59 PM
blue89hatch
Nov 19, 2008 09:00 AM
MCJ420
Jul 22, 2008 04:28 PM
slow91crxdx
Sep 4, 2006 08:38 PM
