Fitting brake cables
Old Nov 6, 2003 | 05:02 AM
bbqman's Avatar
Default Fitting brake cables
Want to know if anyone knows for sure what model I should use for hand brake cables on a Civic 91 si that was previously drum brake, that is now converted to disc brakes.
I used CRX 90-91 si rear trailing arms complete with the calipers and hardware.
Seeing as there are no civic 88-91 rear disc set ups and the cables on my donor trailing arms don't seem to fit.......I need help!
Let me know if you have done this swap and remember what cables went there.
Thanks
Old Nov 6, 2003 | 10:38 PM
SiR Kid's Avatar
New User
Default Re: Fitting brake cables (bbqman)
Use the hand brake(e-brake) cables from a 2 door 90-93 Integra. Those fit my ED hatch perfectly!
Old Nov 6, 2003 | 10:46 PM
HondaRue's Avatar
I would agree with SIR Kid. The cables from a 90-93 integra work just fine. The CRX cables are too short for the HB; however, the crx cables you have are somewhat valuable to those of us who have crx's and want rear disc brakes. The reverse is true for us... the integra cables are too long to fit he crx correctly and new cables from Honda list for around $50- $60. So if you are not going to use them sell them and get the cash for your brake cables and hook someone else up at the same time
Old Nov 7, 2003 | 12:13 PM
bbqman's Avatar
Default Re: Fitting brake cables (HondaRue)
Thanks guys , I figured it out and you confirmed it too.
Old Nov 7, 2003 | 12:16 PM
EL Vap133's Avatar
Good luck and have fun with your install, I can't wait to do mine....
ZCHondaCRX91
Dec 4, 2011 03:03 AM
whyS0serious
12
Jan 23, 2010 09:51 AM
bradennicely
Oct 12, 2009 06:10 PM
racingcrx
Nov 22, 2008 03:43 PM
91_hatch_si
Dec 30, 2002 09:19 PM
