Bleeding brakes? -- take to a shop for that machine to do it?
u can do it yourself but it would be a lot easier to have someone else do it. u just need to know the brake bleeding sequence and someone to help u work the brake pedal.
stick the hose on the nipple...other end of the hose into brake fuild in a bottle (clear one so you can see) (nipple loosened)
push brake pedal
do it until no air comes out (tighten nipple)
be sure to fill the mc each time so air doesnt get back into the lines (close cap fully each time)
easy
push brake pedal
easy
there are 3 ways to bleed brakes they are Gravity bleed, Pump and hold ,& another Way where u use a suction gun
INSTRUCTIONS
gravity-
pretty self explanatory and good if u wanna replace alot of fluid
crack all your bleeder screws on all 4 calipers and let em drain for a while
MAKE SURE U KEEP FILLING YOUR BRAKE FLUID!!!!
Pump & hold-
requires 2 people
have 1 person pump your brake till it's hard(keep holding down brake even when hard but not dont put much strength into it)
once hard have other person open the bleeder screw (be careful brake fluid will shoot a couple feet and can damage paint)
once the pedal goes soft tighten the bleeder screw and repeat
(make sure u dont let off the brake until the screw it tight again)
i suggest doing both if this is your 1st time bleeding your brakes
let em drip for little while and then use the pump and hold method
this shouldn't take u more then 15min. once u got 4 jack stands and wheels off
good luck
honestly though it's about 10 time easier the changing oil in my opinion
Modified by mist Si at 5:53 PM 11/6/2003
INSTRUCTIONS
gravity-
Pump & hold-
requires 2 people
good luck
honestly though it's about 10 time easier the changing oil in my opinionModified by mist Si at 5:53 PM 11/6/2003
do the pump and hold method. it works great you just need a buddy to help out. if you can get all four corners up then it goes really fast.
bleed sequence:
1.right rear
2.left rear
3.right front
4.left front
and if you go to a parts store ,they sell a manual brake bleeder kit,and you dont have to pump your heart out either,all it is is a siphone tube connect to a collection canister and pump suction gun
1.right rear
2.left rear
3.right front
4.left front
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMU1337 »</TD></TR><TR><TD CLASS="quote">should be RR, LF, LR, RF.</TD></TR></TABLE>
sorry but i was always tought, and everyone in my shop was tought to start as far away from the master then go forward. rr,lr,rf,lf.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">
sorry but i was always tought, and everyone in my shop was tought to start as far away from the master then go forward. rr,lr,rf,lf.</TD></TR></TABLE>
that's how i was tought
Please note:
When bleeding your brakes, DO NOT, I repeat, DO NOT push the pedal all the way to the floor. Only push the pedal 5/8-3/4 of the way down. There is debris and other things that settle on the bottom of the resevoir and when you push the pedal all the way down, all the debris moves down into the MC and can easily destroy a perfectly fine MC in no time. If you don't believe me, do a search, it has happened to many people. Also, I have heard that OEM bottles, or any bottle for that matter, of brake fluid is shaped in a way that the bottle can be flipped upside-down onto the resevoir for bleeding purposes. This way, you can be sure that you won't end up pumping the resevoir dry, which is a very big no-no. Just flip her over into the resevoir and make sure it has formed a seal and isn't leaking, then just get to bleeding.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sketch_hs »</TD></TR><TR><TD CLASS="quote">does this gravity method really work??</TD></TR></TABLE>
yup
but takes longer then pump and hold
yup
austinkli
23
Oct 31, 2008 06:26 AM
darwin22
Aug 18, 2004 12:55 PM
