does the sohc f20 use the same timing, and water pump as f22
I as asking cause my gf 90 ex engine is just about toast and i need a quick replacement. Is the only difference being the stroke of the crankshaft?
TIA
TIA
Hey, I have that same engine...
The timing belts did appear to be the same, had the same number of teeth...
i did use an F22A timing belt when I put the f20a4 head onto my f22a1 block temporarily until I get the milled a1 head back on...no trouble so far with the f20 head and an f22a timing belt, IM, cam, etc... at least 2k miles so far...
tdizz07
Feb 21, 2006 03:24 PM
