carb. powered prelude question ???????
Old Sep 7, 2001 | 07:05 PM
4wsB21a's Avatar
New User
Default carb. powered prelude question ???????
i have an 85 prelude dual carb 3 bbl 1.8 - i have hollowed out the cat, put a performance muffler on it, accel wires, top of the line spark plugs, and a k&n filter - i have great low end power, up to about 4000 rpms, but no top end (which i found really odd about a honda). how can i give this car the top end that it needs to keep the power that i want. i can't find a header for it anywhere (if anyone knows where i can get one, let me know), and i just don't know what to do to get the top end power. i am not looking to port it out or change anything like that. i don't want to put tons of money into this car, so please don't suggest a cold air intake, boring it out, or anything like that. i just want to know if there is a simpler way to just give it top end power. please help!!!
Old Sep 7, 2001 | 09:41 PM
rioninja's Avatar
Default Re: carb. powered prelude question ??????? (crxplus)
You probably need to get your carbs adjusted. I have driven in a friends carburated prelude, and it had more than enough topend. There is also a good chance that the carbs are just gummed up, expecially since the car is over 15 years old. Try some in-tank fuel system cleaner as a start, and look into getting them checked out.
Old Sep 8, 2001 | 04:03 PM
4wsB21a's Avatar
New User
Default Re: carb. powered prelude question ??????? (RioNinja)
i actually just got done rebuilding both carbs and putting them back together. one wasn't working right, but now they are both running fine. i then tried all the other things i posted above, but nothing seems to be working. i am still at a loss as to how get the top end power.
Old Sep 13, 2001 | 09:08 PM
4wsB21a's Avatar
New User
doesn't anyone know anything about carbed preludes? come on guys - if someone has something to ask about the f.i. new models, everyone has some info. what about the older models? anyone?
Old Sep 13, 2001 | 10:27 PM
EK-Cruiser's Avatar
New User
That car was made just eight years after I was born. Wish I could help but I was still playin' with Tonkas when your car made it's debut. On the other hand I did use to have a VW bug, and after I rebuilt the carb, I had to play around with it and the distributor to get it to run perfect. I also replaced all my igniton, like distributor, wires, and whatever else. The timing on that car was extremely sensitive, and it took a little trial and error to get it to run like I wanted. Have you considered nitrous? Just a thought.
Old Sep 13, 2001 | 10:28 PM
dustin's Avatar
What is a carburetor?
Old Sep 14, 2001 | 01:17 AM
Gasoline Fumes's Avatar
Default Re: carb. powered prelude question ??????? (dustin)
At least you can spell it.
Old Sep 14, 2001 | 06:51 AM
clockworks's Avatar
Just a wild guess, but is the vacuum advance on the distributor functioning properly? Also, is the fuel pump up to par?
Greg
Old Sep 14, 2001 | 01:47 PM
4wsB21a's Avatar
New User
Default Re: carb. powered prelude question ??????? (clockworks)
thank you - i will give that a try and see if that helps
donald dd
Dec 31, 2006 03:00 AM
OzWolfbane
Mar 9, 2005 04:23 AM
Johnny Groovez
Oct 23, 2004 01:47 PM
tr4il
Honda Motorcycles
Jun 24, 2002 10:44 PM
