Anyone Have a Comptech Tie Bar? NEED HELP
i am trying to help out a fellow h-t'er, he wants to get a comptech tie bar, but they make a comptech tie bar UPGRADE for 94-01 integras for $220 msrp and a comptech 97-01 Type R tie bar for $150 Msrp only, I dont understand... if it's a regular integra with Type R sway bar will the type r tie bar fit?, or must i have type r rear control arms and all.
thanks in advance.
thanks in advance.
i think the upgrade tie bar has the swaybar mounts as extentions on the bar so you will not need to reinforce the subframe with a beaks or bsq kit to use a 22mm rear sway bar.
the type-r setup probibly leaves the swaybar in the stock location and is just a lower tie bar, in which case 150$ is a straight rip-off...
ITR tie bars mount differently. they have a different subframe design.
if its a regular integra w/a type r sway, you'll use a regular tie bar (skunk2, benen etc)
itr specific* tie bars don't fit on regular integras, it doesn't even mount up.
kcjohnnyboy
Suspension & Brakes
30
Aug 27, 2007 01:10 PM
96gsrvtec1986
Apr 9, 2005 07:31 AM
SoCaliGSR
Oct 27, 2001 09:41 PM
