Problem with TAIL LIGHTS! Please help...
Old Sep 7, 2001 | 06:28 PM
DaNish's Avatar
Default Problem with TAIL LIGHTS! Please help...
Ok, my friend has altezza's on his car. He bought them about 3 weeks ago, and has had many problems with them already. He's had to change the bulb in the middle tail light, 3 times already because it keeps turning white and shorting out/shattering. He likes the altezza's, and he doesn't wanna get rid of them, but he can't stand changing the bulbs every three weeks. Has anyone else had this problem with altezza's? Is there something special you need to do to keep the bulb from frying?
Old Sep 7, 2001 | 06:31 PM
DragII's Avatar
25 Year Member
Default Re: Problem with TAIL LIGHTS! Please help... (X DaNish X)
I don't see how the altezza lights would cause the bulb to burn out...they use stock bulbs, and harnesses...he should look elsewhere for a short...or maybe a Water leak
Old Sep 7, 2001 | 07:48 PM
Slopoke's Avatar
Default Re: Problem with TAIL LIGHTS! Please help... (DragIIcivic)
Maybe its gods way of telling him that his car isnt an Altezza.
Old Sep 7, 2001 | 08:33 PM
DaNish's Avatar
Default Re: Problem with TAIL LIGHTS! Please help... (Slopoke)
lol, alright thanks, I'll let him know.
Old Sep 7, 2001 | 08:38 PM
KawiGreenHYBRID's Avatar
New User
I dont' know if he is using stock bulbs from like Kragen or Napa or if he is buying real good bulbs like Polargs but if he is exessvley handling the bulbs specifically the glass portion any grease on his hands or even the oils in your skin can cause the bulbs to shatter..now if they were just burning out I wouldn't know what to tell you but since they are shattering they are probably being handled too much...even stock bulbs will do this but better bulbs are more sensitive...headlights are the same but much more sensitive you cannot even touch the glass on a headlight without ruining it.
Old Sep 9, 2001 | 01:46 PM
DaNish's Avatar
Default Re: Problem with TAIL LIGHTS! Please help... (KawiGreenHYBRID)
Ok, well my friend took it to a mechanic and he said that the problem might be because the bulbs aren't getting enough oxygen, since the light cartridges look air tight. It was weird, because the only bulbs that were going out were the two middle bulbs, so I don't think it was a short, maybe a water leak, but I'm guessing it might of been because they got too hot, which made the bulbs expand and when we pulled them out it cracked, if anyone else had this problem, lemme me so i can tell my friend, otherwise, I'll keep everyone posted on how the holes we drilled in the cartridges effect the bulbs.
Old Sep 9, 2001 | 06:47 PM
PROFILE EK4's Avatar
New User
just tell him to ditch the altezzas and problem solved...
friends dont let friends buy altezza's...
cstone
Nov 23, 2009 03:38 AM
ilikeric3
Aug 13, 2006 07:45 PM
adqnnlude
Mar 21, 2005 09:17 PM
rschoener
Apr 15, 2003 06:21 AM
onyx00
Nov 16, 2001 07:21 PM
