tell me what u think of my NEW EQUAL LENGTH RACE HEADER
Old Nov 5, 2003 | 06:22 PM
97jrscgsr's Avatar
Default tell me what u think of my NEW EQUAL LENGTH RACE HEADER
http://f2.pg.photos.yahoo.com/...iew=t
tell me what u think about it.
Old Nov 5, 2003 | 06:28 PM
elude667's Avatar
Default Re: tell me what u think of my NEW EQUAL LENGTH RACE HEADER (97jrscgsr)
There's more to a header than being equal length. The best path for exhaust is the simplest one. Any disruption of exhaust flow, including bends, takes away power. With all of the extra piping used to make it equal length, you probably lost real-world power with all of the extra weight. There is also more to it than just the gases themselves. You also have to take into consideration pressure waves, which with that much bending, are probably really screwed up and run into each other in the collector in a bad way. I won't even get into the secondary waves being screwed up.
On the other hand, it looks cool
Best way to design a header - Pretend you and someone else are on two seperate slides that merge at the end. You go down a second before the other person. You should end up at the bottom of the slide exactly one second before the other person being as bored as possible.
Old Nov 5, 2003 | 06:32 PM
97jrscgsr's Avatar
Default Re: tell me what u think of my NEW EQUAL LENGTH RACE HEADER (elude667)
the header is using and dyno on a supercharged gsr gain 12hp more than a jdm 4-1 header
Old Nov 5, 2003 | 06:36 PM
elude667's Avatar
What was the total horsepower w/ the jdm 4-1 versus yours. I'd just like to know what the percentage of horsepower gained is. That makes a difference to me at least
Old Nov 5, 2003 | 06:50 PM
97jrscgsr's Avatar
with the JDM 4-1 header on my supercharged GSR i made 219 at the wheel and when i install this race header i made 231 at the wheel
Old Nov 5, 2003 | 07:44 PM
JDMlyfestyle's Avatar
Cant complain about those gains.. Good score
Old Nov 6, 2003 | 04:10 AM
DC2_9's Avatar
Default Re: (JDMlifestyle)
what is the definition/purpose of equal length? they have equal length headers and turbo manifolds.
Old Nov 6, 2003 | 11:54 AM
RacerZook's Avatar
A JDM type R header hinders performance on a SUpercharged motor anyway. Superchargers like short primaries. That header(the twstied one) was not designed with a supercharger in mind either. You could probably spend less time and money with a Kamakazie header and make more power than either header mentioned above.
Old Nov 6, 2003 | 12:15 PM
advanracing62's Avatar
looks like my......
Old Nov 7, 2003 | 07:10 AM
kaosbob's Avatar
Default Re: (RacerZook)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RacerZook &raquo;</TD></TR><TR><TD CLASS="quote">A JDM type R header hinders performance on a SUpercharged motor anyway. Superchargers like short primaries. That header(the twstied one) was not designed with a supercharger in mind either. You could probably spend less time and money with a Kamakazie header and make more power than either header mentioned above. </TD></TR></TABLE>
too bad the kamikaze leaks like a bastard....
Old Nov 7, 2003 | 08:43 AM
KoRE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elude667 &raquo;</TD></TR><TR><TD CLASS="quote">There's more to a header than being equal length. The best path for exhaust is the simplest one. Any disruption of exhaust flow, including bends, takes away power. With all of the extra piping used to make it equal length, you probably lost real-world power with all of the extra weight. There is also more to it than just the gases themselves. You also have to take into consideration pressure waves, which with that much bending, are probably really screwed up and run into each other in the collector in a bad way. I won't even get into the secondary waves being screwed up.
Best way to design a header - Pretend you and someone else are on two seperate slides that merge at the end. You go down a second before the other person. You should end up at the bottom of the slide exactly one second before the other person being as bored as possible. </TD></TR></TABLE>
it looks like there are the same type, and amount of bends that the header has so i don't see how it will be clogged up in the collector please explain?
with the wieght it's probbaly only like 2lbs, nothing to complain about.
Also very nice header looks like my AN-R
Old Nov 7, 2003 | 10:19 AM
97jrscgsr's Avatar
Default Re: tell me what u think of my NEW EQUAL LENGTH RACE HEADER (KoRE)
got it for $460 good deal right?
Old Nov 7, 2003 | 11:44 AM
AllMoToRB18c's Avatar
would u be able to get another one for that price?...that header is really nice i like it
Old Nov 7, 2003 | 12:31 PM
EVIL TYPE R's Avatar
that is an an-r right?
Old Nov 7, 2003 | 12:37 PM
lsvtec hatch05's Avatar
looks tight. good pick up
Old Nov 8, 2003 | 08:59 AM
Default Re: (lsvtec hatch05)
i guess not
Old Feb 2, 2004 | 04:34 AM
massivespeed's Avatar
WICKED HEADER man very impressive........................... hey dave shut up you and your secondary wave
Old Feb 2, 2004 | 06:38 AM
ExospeedAMcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elude667 &raquo;</TD></TR><TR><TD CLASS="quote">There's more to a header than being equal length. The best path for exhaust is the simplest one. Any disruption of exhaust flow, including bends, takes away power. </TD></TR></TABLE>
Im not a super header expert or manufacturer, but I don't totally agree with the comment aout "best path is the simplest one" I have been told by a few old school race engine builders/engineers that this is not necesarily true. In GENERAL it does work, but for maximum torque , that air should travel evenly throughout the piping and that the shorter distances on certain part of the bends will cause turbulence in the flow. if you look at a bending pipe, air can travel faster on one side of the pipe and take longer on the outer side. so to prevent uneven ness i guess, the bends help keep the uneveness all throughout the piping and thus creates more torque.
This is from what I was told. chime in on comments if you want.
in comparison, the Bisimoto header put out 8hp over a stock manifold on a stock D16Z6. Do you think a regular 4-1 DC header will push out that much?
Old Feb 2, 2004 | 10:06 AM
nos51's Avatar
can u get another set?and can u retain the ac with this header(i live in miami,its hot down here)
Old Feb 2, 2004 | 01:38 PM
MaxBoost's Avatar
New User
Default Re: (nos51)
f*ck ac!
Where did you get these control arms? How much lighter are they then stock. Do they have front sway bar mounting points? How much? where?? they look decent!
Old Feb 2, 2004 | 01:51 PM
TodaSi's Avatar
Default Re: (MaxBoost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxBoost &raquo;</TD></TR><TR><TD CLASS="quote">f*ck ac!
Yea, don't mean to hijack your header post, but where did you get those?
Old Feb 2, 2004 | 02:46 PM
dsadas89das78934's Avatar
is this an AN-R piece or Bisimoto ??
Old Feb 2, 2004 | 07:09 PM
PWRVTEC's Avatar
Default Re: (TodaSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TodaSi &raquo;</TD></TR><TR><TD CLASS="quote">
Yea, don't mean to hijack your header post, but where did you get those?</TD></TR></TABLE>
Those are the Competition Engineering control arms and a link in case your interested http://www.competitionengineer...21002
Old Feb 2, 2004 | 07:23 PM
woodog's Avatar
amen.
basic fluid dynamics, let's read about it.
DDTECH
34
Oct 29, 2009 09:50 PM
amimaxima
Jan 26, 2009 03:56 AM
91preyludesi
Oct 29, 2005 12:20 PM
speedyonez
Nov 22, 2003 04:16 PM
ridnmyhonda
Jul 19, 2002 10:17 AM
