MSD Blaster SS Coil Install question...help!!!!!!!!!!!!!!!!!!
Got a MSD Blaster SS coil but there are 3 wires going into a plug for the stock external coil, postive, negative and a green signal? wire....what to do with the green one??? car won't start without now!!!
2 are postive wires, one is ground. get a mulit-meter to test, i dont know accord colors. one might be switched, but dont quote me on that.
The blue one is your ground i believe.
i would solder the connection's to the coil
and run wires w/terminals to the connector
that way you don't have to splice it
well I'm using the accord wiring harness on my h22 so I had a yellow and black/yellow wire which both went to positive end then my green wire(which goes to the ignition control module) went to the negative.
