Anyone running an electric water pump I NEED YOUR HELP!!!!!!
Old Nov 5, 2003 | 03:53 PM
Kwuaymaikrup's Avatar
Default Anyone running an electric water pump I NEED YOUR HELP!!!!!!
I need suggestions and or pictures of your setups. I have the GE pump and am worried about its operation. Can I run it with a stock thermostat? Where should I put it, upper hose? lower hose? I am a bit confused. I have too much into this engine to lose it over a cooling issue. I have to run this due to my deckplate. TIA
-Ryan
Old Nov 5, 2003 | 03:56 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Anyone running an electric water pump I NEED YOUR HELP!!!!!! (Kwuaymaikrup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwuaymaikrup &raquo;</TD></TR><TR><TD CLASS="quote">I need suggestions and or pictures of your setups. I have the GE pump and am worried about its operation. Can I run it with a stock thermostat? Where should I put it, upper hose? lower hose? I am a bit confused. I have too much into this engine to lose it over a cooling issue. I have to run this due to my deckplate. TIA
-Ryan</TD></TR></TABLE>
Lower hose. No thermostat..make a plate to mount it on your tranny.
Old Nov 5, 2003 | 06:45 PM
SCD16A6's Avatar
^ clean install yo!
Old Nov 5, 2003 | 06:46 PM
lucky one's Avatar
Default Re: (SCD16A6)
Old Nov 5, 2003 | 06:51 PM
Default Re: Anyone running an electric water pump I NEED YOUR HELP!!!!!! (SIXTYdashONE)
Do you have any overcooling problems? Do you have it hooked up to a thermo switch or on all the time? Any info would be appreciated since this will be a street/weekend warrior as well. Thanks,
-Ryan
Old Nov 6, 2003 | 01:25 AM
Anyone else?
Old Nov 6, 2003 | 01:34 AM
HT's Biggest Loser
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwuaymaikrup &raquo;</TD></TR><TR><TD CLASS="quote">Do you have any overcooling problems? Do you have it hooked up to a thermo switch or on all the time? Any info would be appreciated since this will be a street/weekend warrior as well. Thanks,</TD></TR></TABLE>
Nah, no overcooling problems, but then again, i dont drive it in the winter, and dont use a stock management, so...As far as it being hooked up, its wired to power on when the fuel pump is powered on, so basically, yeah, whenever the car is running..
Old Nov 6, 2003 | 01:36 AM
Thanks...I am going to try that before I start messing with thermos and such.
-Ryan
Old Nov 6, 2003 | 01:49 AM
HT's Biggest Loser
well i might add that i have my external pump wired to a toggle switch also, if that helps...
Old Nov 6, 2003 | 07:05 AM
DaveF's Avatar
ron, what temp does your car normally run at????
Old Nov 6, 2003 | 08:43 AM
HT's Biggest Loser
Default Re: Anyone running an electric water pump I NEED YOUR HELP!!!!!! (2.2Lcivic)
150 i think is about normal
Old Nov 6, 2003 | 08:45 AM
badCRX's Avatar
New User
FYI:
The Meziere system has you drill two holes (3/16") into your stock thermostat and leave it in.
Old Nov 6, 2003 | 09:42 AM
Default Re: Anyone running an electric water pump I NEED YOUR HELP!!!!!! (badCRX)
Ron, do you run some sort of restrictor plate where your thermo was?
-Ryan
Old Nov 6, 2003 | 11:18 AM
HT's Biggest Loser
I have an autometer temperature guage sender plumbed into the hole...
Old Nov 6, 2003 | 03:15 PM
Jared's Avatar
Ron I remember reading in some sanctioning body's rule book that electric water pumps are illegal in street classes. Has anyone ever given you ****?
Old Nov 7, 2003 | 03:08 AM
HT's Biggest Loser
Default Re: Anyone running an electric water pump I NEED YOUR HELP!!!!!! (Jared)
i dont know what rulebook yer reading, but i think its legal. They are rumored t be illegal next season tho.
Old Nov 7, 2003 | 11:24 AM
93LSivic's Avatar
I remember reading that the Meizer's are only good for about 250 hours of use. Is this true?
BTW. Damn Ron 150 temps is awesome! Are you sure thats how cool the car runs?
Old Nov 7, 2003 | 12:03 PM
racerxadam's Avatar
Default Re: Anyone running an electric water pump I NEED YOUR HELP!!!!!! (93LSivic)
I thought the ideal coolant temp for proper combustion was 180 degrees.
Edit: This article states its closer to 200 degrees F. http://thestar.com.my/services...7.asp
Old Nov 7, 2003 | 01:32 PM
HT's Biggest Loser
Yes Dan, that is true, give or take a few dozen hours, hehe, Yeah 150 at idle
Old Nov 7, 2003 | 03:51 PM
Drag R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic &raquo;</TD></TR><TR><TD CLASS="quote">I remember reading that the Meizer's are only good for about 250 hours of use. Is this true?</TD></TR></TABLE>
When i spoke to Meziere, they told me 2800hrs, with daily driving, should last about 2- 2.5yrs... thats what i was told.
nick
Old Nov 7, 2003 | 08:53 PM
omega11855's Avatar
thats pretty short thinking about the amout of cash they cost
Old Nov 7, 2003 | 09:19 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: (omega11855)
Well they aren't made for daily driving.
Old Nov 8, 2003 | 02:50 PM
Jared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTYdashONE &raquo;</TD></TR><TR><TD CLASS="quote">i dont know what rulebook yer reading, but i think its legal. They are rumored t be illegal next season tho.</TD></TR></TABLE>
found it nopi's rulebook in the turbo 4 specific section, electric water pumps illegal.
Old Nov 9, 2003 | 12:50 PM
chaos_f22's Avatar
bring it......boosted h22a1 turbonics t3/t4e ball bearing turbo.... list to long to tell under 10's
Old Nov 9, 2003 | 01:30 PM
HT's Biggest Loser
Default Re: (chaos_f22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chaos_f22 &raquo;</TD></TR><TR><TD CLASS="quote">bring it......boosted h22a1 turbonics t3/t4e ball bearing turbo.... list to long to tell under 10's
excuse me...
