Mini-me in EF woes
Old Nov 5, 2003 | 03:24 PM
Vince_badaz's Avatar
Default Mini-me in EF woes - NEED HELP!
Hi guys, I've just finish putting a mini-me in my 90 civic. I put the ignition to ON and everything seems fine, fuel pump pressurizes, battery at 12.** volts, etc.
When I try to crank it, there's a loud "bang" from the engine bay and then no power wathsoever, battery voltage drops to 6 volts and there no more juice for accessories and lights
I wiggle then harness and take out/put back the neg on the battery and the whole charade starts again. I check my fuses and there all ok, the problem happens again and again.
I figured it was either a bad short or ground
Apart for that, any ideas on what it could be. This car has to run before snow falls (which was yesterday here)
Thanks
Modified by Vince_badaz at 2:23 PM 11/6/2003
Old Nov 6, 2003 | 05:23 AM
Default Re: Mini-me in EF woes - NEED HELP! (Vince_badaz)
ttt need help guys come on
Old Nov 6, 2003 | 05:33 AM
feelsfast's Avatar
I would double check your timing I'm not sure if this is your problem but I would check it anyways. Also make sure you have the right ecu for the job.
Old Nov 6, 2003 | 05:45 AM
Default Re: (feelsfast)
I'm using a P28 with a Blown90hatch OBD-1 conversion kit and the cam timing has been checked about six times...
I didn't get the chance to set up ignition timing since the car hasn't been running but I put the distributor in as fairly conservative position so I don't think that it is it.
Old Nov 8, 2003 | 03:16 PM
Any other ideas?
Old Nov 8, 2003 | 03:48 PM
CRX Si's Avatar
sounds like an electrical problem so the first thig I would do is check your grounds, and then check to see if there is anything shorting out somewhere...
Alanhino
Jan 2, 2012 05:32 PM
efb20vtec
Nov 26, 2006 01:37 PM
9311dan
Nov 13, 2006 05:44 AM
ITR43
Nov 19, 2004 07:51 AM
Vince_badaz
Nov 5, 2003 04:27 AM
