4th gen, where did u put your hood pin
I'm tryin to put hood pins in, but i can't find a good spot, the only good place looks like i have to cut away some parts of the plastic mountings for the headlights..which i dont want to do if i can avoid it, or if it doesnt effect anything, can i see some pics of where u guys put you pins in..
ok cool, thanks i'll check it out*edit* SKDRKR thanks, that's where i was gonna put them, i just wanted to make sure it would fit, doesn't look like i'll have to cut anything, thanks for the pic, it helped alot
Modified by SpoolBlude at 1:55 AM 11/6/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolBlude »</TD></TR><TR><TD CLASS="quote">ok cool, thanks i'll check it out*edit* SKDRKR thanks, that's where i was gonna put them, i just wanted to make sure it would fit, doesn't look like i'll have to cut anything, thanks for the pic, it helped alot
Modified by SpoolBlude at 1:55 AM 11/6/2003</TD></TR></TABLE>
koo, b4 you drill the holes out for the hood, install the hoodpins
in the rad supt., and put some silicone or something on the
top of the pins, and set the hood down on them to get your
markings, then drill from the inside out
p.s. make sure you dont drill at an angle
Speed Weed
Mar 3, 2016 12:47 PM
fu*kfaceC1EH2
Aug 6, 2003 06:16 PM
