best intake manifold for a gsr
Old Nov 5, 2003 | 09:09 AM
Grimm's Avatar
Default best intake manifold for a gsr
Like it says folks... Looking for a good intake manifold to produce more low to mid range power. Was looking at skunk 2 and edelbrock or type r... I know edelbrock gets added power in the higher end of things but don't know about the others.
Any personal experience to go along with the choicees would be great....
Old Nov 5, 2003 | 09:36 AM
Project SSAP1's Avatar
Default Re: best intake manifold for a gsr (Grimm)
well lets c...for more low end power both the skunk2 and the JG will kill a lil low end but will have nice gains in the high end...i would not suggest the JG because it is really meant for all out motor apps or turbo..and only gains r in the ext. high end for all motor...if u just have simple bolt ons keep the stock mani until u get some doe to get everything that is needed for the skunk2...i feel in order to get the most gains out of the skunk2 u need the following:
at least ITR cams
ITR TB or equv.
obd1 ecu...go for a nice P28 chipped or
hondata s100 or 200
itr throttle cable..
itr style intake..aem, icebox, j's..etc
also i would check the fuel pressure with the new mani and other lil stuff...with all this new stuff u might notice a slight decrease in low end but u will have killer top end..
all these suggestions i have made i feel will compliment the new skunk2 mani very well...
Old Nov 5, 2003 | 12:29 PM
gsrvx's Avatar
New User
I would just go with a skunk2. I didn't feel much if any loss low end...but great high end.
Old Nov 5, 2003 | 01:04 PM
DaveF's Avatar
Default Re: best intake manifold for a gsr (ibspecHATCH)
how do you feel about erick aguilar running a stock b18c intake manifold???at least it looks stock on the outside anyhow.
Old Nov 5, 2003 | 01:09 PM
snowseeker's Avatar
Default Re: best intake manifold for a gsr (2.2Lcivic)
Sheet metal intake!
Old Nov 5, 2003 | 01:20 PM
Grimm's Avatar
Default Re: best intake manifold for a gsr (Project H22DC4)
Thanks for the info...
I currently am running:
generic intake
dc 2 piece stanless 4-2-1 headers
apexi ws exhaust
apexi vafc
I'd like to understand why you suggest the following:
obd1 ecu
itr thottle cable
The others I kinda understand... thanks again
Old Nov 5, 2003 | 01:48 PM
thegrinch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic &raquo;</TD></TR><TR><TD CLASS="quote">how do you feel about erick aguilar running a stock b18c intake manifold???at least it looks stock on the outside anyhow.</TD></TR></TABLE>
you said "STOCK" ........ we all know that it is not stock. But it has to flow really well.
Old Nov 5, 2003 | 03:30 PM
turbod15's Avatar
Default Re: best intake manifold for a gsr (thegrinch)
Simple cut out all the crap out of the gsr manifold and run 2 plates to make the plenum larger. Lots of porting but it works.
Old Nov 7, 2003 | 08:24 PM
People around here get the Skunk2 intake manifold for their GSR's(b18c1) so their Vtec is LOUDER! sadd but true... But id have to agree on getting the Skunk2 intake manifold for a nice simple set-up like: Skunk2 Manifold, CTR Cams, Spoon Balanced ITR Pistons, STR Cam gears, and a JDM 4-1 Header..oh yea and if your running stock valvetrain get some ITR Outer Valve springs...and you can revv up to 9k.. oh yea correct me if im wrong on ne-thing
Old Nov 7, 2003 | 08:45 PM
dohcter g's Avatar
I am sure it is ported all to hell!
Old Nov 8, 2003 | 06:50 AM
DC2_9's Avatar
i believe the type r intake manifold will not fit onto your gsr head
Old Nov 8, 2003 | 09:21 AM
AussieK24's Avatar
Default Re: best intake manifold for a gsr (turbod15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbod15 &raquo;</TD></TR><TR><TD CLASS="quote">Simple cut out all the crap out of the gsr manifold and run 2 plates to make the plenum larger. Lots of porting but it works.</TD></TR></TABLE>
I doubt there is anything "simple" in Ericks manifold. Probably more time and effort in his IM than most people put into there entire setup
Old Nov 11, 2003 | 09:10 AM
Grimm's Avatar
Default Re: best intake manifold for a gsr (DC2_9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2_9 &raquo;</TD></TR><TR><TD CLASS="quote">i believe the type r intake manifold will not fit onto your gsr head</TD></TR></TABLE>
EXCELLENT POINT
Old Nov 11, 2003 | 09:19 AM
BolivianDc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grimm &raquo;</TD></TR><TR><TD CLASS="quote">Like it says folks... Looking for a good intake manifold to produce more low to mid range power. </TD></TR></TABLE>
If you want low and midrange power, don't bother buying a new manifold
Old Nov 11, 2003 | 09:48 AM
-KangaRod-'s Avatar
all those new manifold are not shaped properly for that head...
Only the stock IM or a custom IM would be best, although on a budget a SK2 or AEBS would be good on the street.
-edit-
A modified stock one will make more low end power than all those other ones. Victor X doens't make any lowend, the SK2 makes some, but not as much as stock, the AEBS will make more, but still if low end is where you're at, modified stock might be best.
Old Nov 11, 2003 | 10:01 AM
DVS_EF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ibspecHATCH &raquo;</TD></TR><TR><TD CLASS="quote">I would just go with a skunk2. I didn't feel much if any loss low end...but great high end.</TD></TR></TABLE>
Old Nov 11, 2003 | 11:04 AM
SAVAGE99's Avatar
Default Re: best intake manifold for a gsr (dvsEF)
skunk 2, cool humming
Old Nov 11, 2003 | 06:25 PM
take a look at this ported gsr intake mani...i feel this will rip the skunk2 a new ***!!! i still feel that a gsr mani like this will kill the skunk2 mani low to midrange and as well as high end...plus with a nice set of cams like toda b or c that has sick midrange when tuned correcty...OMG...plus hondata and a obd1 P72..u guys wait and c...a oem mani i feel is better than the skunk2 unit...plus honda made this thing for a reason...stick with it..
Old Nov 11, 2003 | 08:21 PM
smnowell's Avatar
You guys seem to be missing one option that gives you the best of both worlds....ported skunk2 manifold. I don't know who has and hasn't been to Endyn's website, but Larry ports Skunk2 manifolds like nobodys business Pics borrowed from http://www.theoldone.com
Old Nov 13, 2003 | 06:24 AM
Default Re: best intake manifold for a gsr (b16a ferio)
damnit..i posted that endyn manifold a bunch of times and nobody said a thing...lol...but now that manifold is a different story...that thing is actually done right..like 2lbs r shaved off...but the price is about 850 which includes the mani..so its not that bad..and they said it flow like ITB's...i dont know about that but hey
Old Nov 13, 2003 | 08:52 AM
smnowell's Avatar
I believe when that Endyn manifold is finished, the have to put some coating on the inside (forgot what it was) because it was so thin that under vacuum it would actually start to cave in...atleast, this is something that I have heard in regards to that ported Endyn manifold. Still, it is a badass manifold, but kinda pricey
Old Nov 13, 2003 | 09:12 AM
BERT-O's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a ferio &raquo;</TD></TR><TR><TD CLASS="quote">You guys seem to be missing one option that gives you the best of both worlds....ported skunk2 manifold. I don't know who has and hasn't been to Endyn's website, but Larry ports Skunk2 manifolds like nobodys business Pics borrowed from http://www.theoldone.com
So does Brad, aka MAX_CFM,
For more info,
http://www.hondaraceengines.co....html
-Bert
Old Nov 13, 2003 | 09:23 AM
P1mpSlap's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project H22DC4 &raquo;</TD></TR><TR><TD CLASS="quote">take a look at this ported gsr intake mani...i feel this will rip the skunk2 a new ***!!! i still feel that a gsr mani like this will kill the skunk2 mani low to midrange and as well as high end...plus with a nice set of cams like toda b or c that has sick midrange when tuned correcty...OMG...plus hondata and a obd1 P72..u guys wait and c...a oem mani i feel is better than the skunk2 unit...plus honda made this thing for a reason...stick with it..
Damn, I thought I was the only one who thought about this. Do you have pics of the stock GSR manifold for comparison? What about dynos? I am very interested in this.
Old Nov 13, 2003 | 11:10 AM
bulori's Avatar
hey can someone post the Stock gsr IM and a dynno graph would help .
Old Nov 13, 2003 | 12:08 PM
Default Re: best intake manifold for a gsr (bulori)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bulori &raquo;</TD></TR><TR><TD CLASS="quote">hey can someone post the Stock gsr IM and a dynno graph would help .</TD></TR></TABLE>
i will once i get some pics...
