JDM hood not lining up.
Old Nov 5, 2003 | 03:35 AM
Home Skillet's Avatar
Default JDM hood not lining up.
Has anyone had any problems with their JDM hood latch being 2" away from the release? Are the JDM latches the same as the USDM?
Old Nov 5, 2003 | 03:38 AM
davens's Avatar
The ZC hoods will bolt onto USDM front ends.
SiR hoods will not...the latch would be, oh...2", from where it needs to be.
Old Nov 5, 2003 | 03:44 AM
Default Re: (davens)
Thank you Captain Obvious. Anyone else with useful information?
Old Nov 5, 2003 | 03:53 AM
davens's Avatar
Default Re: (Home Skillet)
okay ********...are you trying to bolt an SIR hood to a USDM front end? Because trying that will cause the exact problem you're describing
Old Nov 5, 2003 | 03:57 AM
crxforum's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davens &raquo;</TD></TR><TR><TD CLASS="quote">okay ********...are you trying to bolt an SIR hood to a USDM front end? Because trying that will cause the exact problem you're describing</TD></TR></TABLE>
He is right. You need the fenders, headlights, hood hinges and some other poop to make it work right.
CRX Forum
Old Nov 5, 2003 | 04:08 AM
I have the JDM bumper, headlights, filler, radiator support, and from what I was told you don't need the fenders. I do not have the hinges though, I didn't think I needed those as well.
Sorry Davens, it's early for me and I was up til 2AM this morning trying to get this thing right, my comment earlier wasn't neccesary.
Old Nov 5, 2003 | 04:55 AM
davens's Avatar
It's cool...you're braver then me. I'd have that thing at a body shop.
I was trying to see which hood, which front end...coulda made that a little clearer.
Old Nov 5, 2003 | 05:41 AM
Default Re: (ImsorryHonda-tech)
The only difference I noticed about the JDM vs USDM radiator support was the hole for the stock air intake box, correct me if I'm wrong.
Old Nov 5, 2003 | 05:58 AM
schwanginpt's Avatar
Home Skillet you're absolutley right.
you dont need the fenders, and the rad support is the same except for the air intake.
its the front cross support.. its "back" on the USDM CRX than the JDM. i had to modify stuff to get it to work. I moved the latch back, and moved the latch forward and shimed the rad support forward
i have a link.. check it out
http://www.jdmuniverse.com/for...13089
if you have any questions, let me know!
Old Nov 5, 2003 | 06:41 AM
'90 ZC REX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davens &raquo;</TD></TR><TR><TD CLASS="quote">The ZC hoods will bolt onto USDM front ends.</TD></TR></TABLE>
Doesnt bolt up to Up eh? Guess I should take it off then.....
Old Nov 5, 2003 | 06:48 AM
Default Re: (schwanginpt)
Man, that's exactly what I was lookin for. I didn't know if I was missing a part or what not. Very informative link. Thanks Schwanginpt
Old Nov 5, 2003 | 07:29 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: ('90 ZC REX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by '90 ZC REX &raquo;</TD></TR><TR><TD CLASS="quote">
Reading comprehension owns you...
stan
Old Nov 5, 2003 | 07:35 AM
'90 ZC REX's Avatar
Reading &gt; You
You were saying? No mods to put the ZC hood on my USDM CRX. That is the point I was making.
Mike
Old Nov 5, 2003 | 08:39 AM
xci_ed6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by '90 ZC REX &raquo;</TD></TR><TR><TD CLASS="quote">Reading &gt; You
Mike
And after davens said it will work, you said:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Doesnt bolt up to Up eh? Guess I should take it off then.....</TD></TR></TABLE>
Which doen't make sense unless you thought he said it would not work. So, after all, reading comprehension DOES own you. So does writing, because your rehtorical question makes no sense. You even quoted him.
To review:
davens - it does work
you - you are wrong, it works, see pic
90crxSi - davens said it works
you - no it works, i had a pic
-Dustin
Old Nov 5, 2003 | 08:48 AM
davens's Avatar
*rolls eyes*
Old Nov 5, 2003 | 09:09 AM
'90 ZC REX's Avatar
I guess reading does own me....
Oh well shows what being up for 21hours does to ya....
Mike
Old Nov 5, 2003 | 09:24 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Home Skillet &raquo;</TD></TR><TR><TD CLASS="quote">Man, that's exactly what I was lookin for. I didn't know if I was missing a part or what not. Very informative link. Thanks Schwanginpt </TD></TR></TABLE>
hey sure thing man.. i remember when i was researching this, i was getting a bunch of different stories of how to make it work. 2 suggestions were correct. 1 person used nothing but washers to shim the rad support forward, the other person said to just cut and slide the latch back on the hood. both became noticeable, and i didnt like that soo much, so i comboed the 2 and modified the latch to make it be more subtle.
If anything doesnt make sense, let me know and i will do what i can about explaining it better post pics when you get it done!
Old Nov 5, 2003 | 09:30 AM
EF_LSVtec's Avatar
Here's what I did...pic will explain.
Old Nov 5, 2003 | 10:32 AM
fourthgenhatchB17's Avatar
Default Re: (EF_LSVtec)
i happened to get my JDM front clip off a EF1. Those radiator supports are perfect and are much wider to compensate for the 2 inch gap. I hear that the support off the EF2 also works perfectly. There is a pretty noticable difference between the EF9 rad. support and the EF1/2. When i installed my friends front end, he got an original EF9 one and i bolted it up without using washers/spacers, but instead i just bent (very carefully) the middle section, where the latch is, out as far as needed with my handy 5lb. sledge.
Old Nov 5, 2003 | 11:04 AM
b16_madman's Avatar
hmm...it took me a minute to figure out what's goin on in the pic, but eureka I found it!
can you do this w/the usdm support as well?
Glad to hear of this problem before I order mine.
Old Nov 5, 2003 | 11:10 AM
xpsonic's Avatar
Default ..
nice....mine hasnt fit forever... gotta get to work on making it fit now... nice pics though.
Old Nov 5, 2003 | 11:36 AM
yea.. you can do that with the USDM rad support. only difference is the hole for the intake box on the JDM ones
Old Nov 5, 2003 | 11:55 AM
soulstream's Avatar
This was my solution. Extending the radiator support with washers like EF_LSVtec, but using the USDM radiator support.
Old Nov 5, 2003 | 01:20 PM
crxgator's Avatar
Default Re: (soulstream)
man after reading this post...it seems that the ED forum needs to go back to school to learn how to read...
incognito E46
May 12, 2007 01:16 PM
ballermc5
11
Sep 6, 2006 08:08 AM
ef-b16sedan
Jun 22, 2006 02:23 PM
Jay.D.Em!
Jan 10, 2006 08:14 AM
wrXtian
Mar 4, 2003 04:24 PM
