Ground control ride height?
Old Nov 4, 2003 | 09:02 PM
John O's Avatar
Default Ground control ride height?
I'm sure this has been asked before but how much would a 7" ground control spring lower my car?
-Thanks.
Modified by John O at 1:18 AM 11/5/2003
Old Nov 4, 2003 | 09:45 PM
kyler's Avatar
Default Re: Ground control ride height? (John O)
I may be wrong but the only Ground Control springs I know of have adjustable perches.
So the amount it lowers your car is up to you.
Old Nov 4, 2003 | 09:56 PM
insomniac791's Avatar
yea al Ground controls have perches you adjust them yourself
Old Nov 4, 2003 | 09:57 PM
John O's Avatar
Default Re: (insomniac791)
I know but don't the springs lower the car and automatic amount with out any adjustment? I've heard 2".
-Thanks.
Old Nov 4, 2003 | 10:01 PM
kyler's Avatar
Default Re: (John O)
No, when you spin the perches onto the threaded sleeve you have to adjust them.... theres nothing "preset" about them.
Just read the instructions and you'll be fine.
Old Nov 4, 2003 | 11:18 PM
Vinceg99's Avatar
Default Re: (kyler)
Hey John your right you can buy "lowered" springs for them sorry cant help you with how much it lowers it but I think your right with the 2" though, I believe stock height is 9".
Old Nov 5, 2003 | 06:45 AM
John O's Avatar
Default Re: (Vinceg99)
Thnaks for the replies, can anyone confirm the 2".
Old Nov 5, 2003 | 08:59 AM
Quik89Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by John O &raquo;</TD></TR><TR><TD CLASS="quote">Thnaks for the replies, can anyone confirm the 2". </TD></TR></TABLE>
No, nobody can confirm the 2".
The thing is that the 7" or 8" (whichever you choose for various reasons) spring that comes with the kit sits on the adjustable perch. Now, if you have the perch set at its highest setting all the way at the top, it'll probably raise the car about 1/2".
If you have it all the way at the bottom, it'll probably drop the car right around 3". So you see, there's no SET DROP at all with Ground Controls or any other sleeve type coilover setup.
The only set drop you'll find is with a spring kit, like Eibach Sportlines or Neuspeed Sports - and even then, the drop isn't certain, due to weight of different motors, sagging of the springs, etc.
Hope that clears it up!
Alex
Old Nov 5, 2003 | 09:08 AM
John O's Avatar
Default Re: (Quik89Si)
ok, thanks for the help.
Old Nov 6, 2003 | 10:29 AM
travis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quik89Si &raquo;</TD></TR><TR><TD CLASS="quote">
Choose a spring length that will give you the most flexability in ride height changes from the perch. For example, a 6" spring and an 8" spring could be set to the same ride height using the adjustable perch. However, there's only so high the 6" can go, and there's only so low the 8" will go.
Old Nov 6, 2003 | 06:53 PM
Alan Wil's Avatar
Best thing to do is to CALL Ground Control.
Tell them what you are doing and they can tell you what springs to get. Sounds like maybe you've found some springs used?... and maybe off some other kind of car?
So far as how much the car will be lowered depends on not only the length of the springs but also the strength of the springs. (Spring rate)
If you had say a 200lb spring and a 900lb spring with the same amount of weight on them the lower rated spring would deflect more. (Compress more)
bentbeat
Honda Civic (2006 - 2015)
May 16, 2008 06:27 PM
BIG T
Suspension & Brakes
Dec 31, 2007 08:29 PM
RED_90TEG
Suspension & Brakes
Jul 7, 2006 12:26 PM
silentkill03
Oct 26, 2004 02:49 PM
phoenix down
31
Nov 10, 2003 02:32 PM
