Would I break 12's with slicks????
Old Nov 4, 2003 | 05:39 PM
civic5513's Avatar
Default Would I break 12's with slicks????
My car is '90 integra with stock allmotor b18c1, y1 tranny with 4.4 lsd
mods: short ram intake, open header, flywheel
Current pb: 13.488@104.5 with a 2.169 60'
and 13.560@104.3 with 2.212 60'
Both runs on 205/50/15 Azenis
With MT 22/8/15 would it be possible to break 12's with my current setup?
Modified by civic5513 at 3:31 AM 11/5/2003
Old Nov 4, 2003 | 06:54 PM
boostsohfast's Avatar
Default Re: Would I break 12's with slicks???? (civic5513)
104 is definately enough mph to get into the 12's with slicks.
Old Nov 5, 2003 | 03:36 AM
EIT_certified's Avatar
Default Re: Would I break 12's with slicks???? (boostsohfast)
I don't know.......if u get real close like 13.0, do suspension
Old Nov 5, 2003 | 03:47 AM
eRACING's Avatar
Default Re: Would I break 12's with slicks???? (sheemo3)
if your running the 13.4-5's consistantly on the street tires then yes you should break into the 12's if not come really really close on the slicks (13.0). Suspension will do wonders for your setup (lowered front, soft front shocks-Raised back, stiff back shocks, etc...)
Old Nov 5, 2003 | 09:47 AM
AussieK24's Avatar
Default Re: Would I break 12's with slicks???? (erics99si)
I think you might just come up short. Slicks should take a mph or two off you, leaving you JUST short, IMO
Old Nov 5, 2003 | 09:50 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: Would I break 12's with slicks???? (AussieK24)
Yeah you should. My buddy's N/A 4-door GSR runs consistant 13.4-5's on streets w/ 2.1-2.2's and 12.8's on slicks w/ 1.7-1.8's.
Old Nov 5, 2003 | 02:50 PM
SadisticRacing's Avatar
Default Re: Would I break 12's with slicks???? (Mr Milano)
I would say yes but go with M&H slicks instead!!
Old Nov 5, 2003 | 05:33 PM
3rdGteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic5513 &raquo;</TD></TR><TR><TD CLASS="quote">My car is '90 integra with stock allmotor b18c1, y1 tranny with 4.4 lsd
Modified by civic5513 at 3:31 AM 11/5/2003</TD></TR></TABLE>stock running 13's in that chassis? Wow!
Old Nov 5, 2003 | 05:59 PM
JBk24crx's Avatar
I dont see why not.
Old Nov 5, 2003 | 06:30 PM
dattegbol's Avatar
not to hyjack but do you think i will on slicks
setup :
stripped std 91 hatch. 1896lbs with me 2 gals of gas.
92b18a1 pnp head .040 shaved.,colt cams , adj. cam gears, portmatched int. , short ram, header, msd sci , taylor pro 49 wires, str fuel rail , adj fpr. 2.5 in exh. no cat, safc , prolite act flywheel , ctr pulley alt. only. , clutchmasters clutch, 92 gsr ys1 tranny, . fresh bottom end, fresh valve job . thanks sorry
Old Nov 5, 2003 | 07:41 PM
831HondaAllmotor's Avatar
well i have a
1995 civic hatch
single cam vtec engine with head work with 70 shot direct port.
fully ported head
hondata tuned
lsd tranni
on m &H slicks.
high comp bottom. 11:1comp
Built by Exessive motorsports
12.83@107
Old Nov 5, 2003 | 07:44 PM
strhhsr
Old Nov 6, 2003 | 08:05 AM
skunked's Avatar
see sig.
You should be able to get there with good driving and a 1.7-1.8 60'
Old Nov 6, 2003 | 12:32 PM
Gorm's Avatar
Default Re: Would I break 12's with slicks???? (skunked)
What size slicks? I am running 20X8X14 M/T slicks and can only get 1.94 60 ft times and 13.52@100.4 mph. I think Im shifting before the 60ft mark and its killing the times, even if I get a good 1-2 shift. Im thinking of going to a 22X8X13 anybody using this?
Gary
Old Nov 6, 2003 | 01:48 PM
skunked's Avatar
Default Re: Would I break 12's with slicks???? (Gorm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gorm &raquo;</TD></TR><TR><TD CLASS="quote">What size slicks? </TD></TR></TABLE>
I run 22x8's on 13" bogarts. The power output and gearing will determine what size slick you should run.
Old Nov 6, 2003 | 02:03 PM
SlicksMH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">
I run 22x8's on 13" bogarts. The power output and gearing will determine what size slick you should run.</TD></TR></TABLE>
(skunked) is right, IM me this info.
(1) What is your Overall FD and the gear size you have in 4th.
(2) What speed and rpm do you want to be @ in 4th gear, threw the traps.
John@M&H-Hashim's
Shake and Bake
Jun 24, 2006 01:37 PM
Soda Popinski
Nov 21, 2005 07:24 AM
SiR831
Sep 4, 2003 11:24 AM
Cyber ITR
Apr 21, 2003 04:54 PM
HX_Guy
Jul 14, 2001 01:08 AM
