95 accord want to swap a 5 spd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crvtec00 »</TD></TR><TR><TD CLASS="quote">Can I swap a manual transmission in for the f22 in a 95 accord? If so what tranny? H22?</TD></TR></TABLE>
f22, h23, h22 manual trannies..take your pick, they'll all bolt right up. the h22 has the shortest gearing and you can get it with a LSD, so that would preferable.
dont expect any of the options to be cheap though.
It cost me a little extra to swap my automatic Accord to a 5 spd during the time when I was doing H22 motor swap.
I had to buy the tranny mount for (40) and back (triangle mount) for (80).
The front and driver side mount were the same.
(113) for the clutch master cylinder with the reservoir from Honda.
(26) for the clutch hard line and (50) for the shift linkage.
I also had to buy the 5 speed pedal assembly for around (60).
You will also need 5 speed Accord axles and half shaft.
I know that I am leaving out other small stuff.
The tranny came with my motor as a complete swap. If you are looking for a H22 tranny, I think they are around like 700. If you are lucky, you might be able to find one for 400. Make sure that the transmission won't grind because you will not be happy with it.
