CRX B16 SWAP
hey guys i need some help i did a swap A B16A SIR 1 into my 90 crx si but vtec does not work however it works if i manually engauge it just powering up the spool valve at like 4000rpm but i want it to work by itself also i hit the rev limiter at 7000 i have a pr3 ecu i think is should be at 8200 here are the pinouts for the vtec harness see if they match yours or if you think they are wrong... thanks
2ond o2 sensor c 8
vtec soleniod a8
vtec oil pressure switch b 5
knock sensor b 19
all theese are with the clips up and the wires facing away.. the cel is not on at this time thanks ,
2ond o2 sensor c 8
vtec soleniod a8
knock sensor b 19
