15" tires, what pressures you running??
Old Nov 4, 2003 | 04:14 PM
gribbs's Avatar
Default 15" tires, what pressures you running??
INterested in tire pressures and what most of you are running and why.
Old Nov 4, 2003 | 04:21 PM
D16OnTop's Avatar
38ish
Old Nov 4, 2003 | 04:22 PM
KiDSoL's Avatar
Default Re: 15" tires, what pressures you running?? (gribbsEG8)
40 one mine.
Old Nov 4, 2003 | 04:23 PM
h22John's Avatar
32 on the street , falken azenis cuz im a biotch heh
jeremyEG's Avatar
Default Re: 15" tires, what pressures you running?? (KiDSoL)
it all depends on what tires you have. i run mid to high 30's on my azenis.
Old Nov 4, 2003 | 05:06 PM
t0p_sh0tta's Avatar
Default Re: 15" tires, what pressures you running?? (jeremyEG)
Why so high?
Old Nov 4, 2003 | 05:15 PM
Mike_C's Avatar
34/32 on the street, 38/36 at the track and 38/40 for autox.
Old Nov 4, 2003 | 08:44 PM
quik sol's Avatar
Default Re: (JMU1337)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMU1337 &raquo;</TD></TR><TR><TD CLASS="quote">34/32 on the street, 38/36 at the track and 38/40 for autox.</TD></TR></TABLE>
what am I missing here...that makes no sense....high tire preassure on the track??? thought you were supposed to run lower in a 1/8-1/4 track racing...
Old Nov 4, 2003 | 08:49 PM
DV98CVC's Avatar
Default Re: (quik sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik sol &raquo;</TD></TR><TR><TD CLASS="quote">
what am I missing here...that makes no sense....high tire preassure on the track??? thought you were supposed to run lower in a 1/8-1/4 track racing...</TD></TR></TABLE>
i'm confused aswell...what would eveyone recommend for 16's? street/track
Old Nov 4, 2003 | 08:50 PM
Chris y0!'s Avatar
35 all around street
40 front 38 rear track
falkens...
Chris y0!'s Avatar
he means a real track. the kind with turns.
Old Nov 4, 2003 | 08:52 PM
esoterEK..'s Avatar
35 avid t4 yoko
Old Nov 4, 2003 | 10:42 PM
tangb2023
Guest
Posts: n/a
Default Re: 15" tires, what pressures you running?? (EGkwazhimoto)
32 in front 33 34 on rear.. i keep the rear stiffer so i can drift easy
Old Nov 4, 2003 | 11:17 PM
D16Z6racing's Avatar
Default Re: 15" tires, what pressures you running?? (tangb2023)
35 - Toyo Spectrum
36 - Kuhmo 711
Old Nov 4, 2003 | 11:21 PM
Downey's Avatar
Summer Tires : 205/50-15 Azenis front 33psi rear 35psi
Winter Tires : 195/50-15 Potenza S03 front 32psi rear 34psi
Old Nov 5, 2003 | 01:41 AM
quik sol's Avatar
oh, he said "36-38 on the track and 40 auto-x'in"....so i figured he was talking drag....I was about to say i run 22-24 psi on my street tires on the drag strip
lude98SH
Mar 25, 2008 10:03 AM
Freeltec
Nov 2, 2005 05:30 PM
Vitt1
12
Jul 5, 2005 01:34 PM
SloCivicHMM
May 17, 2005 05:05 AM
Utilitarian
14
Dec 8, 2004 09:01 AM
