what's the best obd0 ecu (pr3, pg7, etc.) i can use with d16z6 crx si
just what it says, what ecu will give me the best power gains. would i be able to use a obd0 vtec ecu and engage vtec from it?
none of them...either way your going to have to use an rpm acticated switch to activate vtec, unless u go obd1. The teg ecu is supposed to have the best fuel and ignition curves for the SOHC. So get a pg7 and rpm switch and go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatrick2332 »</TD></TR><TR><TD CLASS="quote">none of them...either way your going to have to use an rpm acticated switch to activate vtec, unless u go obd1. The teg ecu is supposed to have the best fuel and ignition curves for the SOHC. So get a pg7 and rpm switch and go.</TD></TR></TABLE>
very helpful, thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brownjd »</TD></TR><TR><TD CLASS="quote">
very helpful, thanks</TD></TR></TABLE>not really hes that helpful (dont take it personal bro)
for a SOHC VTEC u got a few options
1- u can go OBDI conversion and use the right ecu P28
2- u can use a OBDO PR3, PWO B16ECU chipped but u will have a very high and dangerous redline ( u can chip these and make vtec kick around 4500-5000 etc)and change programs like Mugen, Toda, etc
3- u can use any OBDO ECU PR4, PG7, PM6, and use some sort of vtec controler (Apexi or Field's)
4- u can get a Zdyne 1 wire conversion ecu
5- or u can just get Hondata for the OBDO cars....
from all of them the Zdyne SECU or Hondata on the OBDO or OBDI will be the best
I'm using a automatic PR3 on my mini-me. I'm hoping that the less aggressive mapping of the auto ecu won't make the engine run so rich, and the rev-limit on the auto ecu is lower as well (7400 rpm, I believe). I haven't put the car on the dyno yet, so I'm not real sure how this route of engine management works out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 »</TD></TR><TR><TD CLASS="quote">I'm using a automatic PR3 on my mini-me. I'm hoping that the less aggressive mapping of the auto ecu won't make the engine run so rich, and the rev-limit on the auto ecu is lower as well (7400 rpm, I believe). I haven't put the car on the dyno yet, so I'm not real sure how this route of engine management works out. </TD></TR></TABLE>
Of course, you have to run that STUPID twin oxygen sensor setup if you go PR3.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt »</TD></TR><TR><TD CLASS="quote">
Of course, you have to run that STUPID twin oxygen sensor setup if you go PR3.</TD></TR></TABLE>
not unless u chip the ecu
Yeah, for now the car runs a little rough without the second O2. I don't know if I'm going to rechip it or just install the second O2.
if you can get your hands on a pr3/pw0, just use turboedit (www.turboedit.org) to chip it and lower the rev limit to acceptable levels and import some z6 maps. that way you have pretty much a p28 without the hassle of a wiring conversion.
I've run the auto JDM PR3 DOHC ECU on my SOHC VTEC swap for some time. It run very well. I still have the downpipe for sale with proper O2 bungs locations.
1990hondaHF
Aug 10, 2005 06:23 AM
jspechatch04
Feb 10, 2004 12:59 AM
Brownjd
Nov 4, 2003 12:57 PM
