Street Tire pressure?
Old Nov 4, 2003 | 11:27 AM
C8V6C's Avatar
Default Street Tire pressure?
What is the best tire pressure to run on street tires? I have some 15 inch **** tires with 51 psi and want to lower my 1/4 time.
Old Nov 4, 2003 | 11:39 AM
redboost10's Avatar
Default Re: Street Tire pressure? (C8V6C)
15-20 psi
Old Nov 4, 2003 | 11:42 AM
C8V6C's Avatar
Default Re: Street Tire pressure? (tgh99si)
How much would it help on the 60ft? Last time I ran, I didnt even think of the tires and ran them probably at 45 psi. 60 ft was crap.
Old Nov 4, 2003 | 11:54 AM
redboost10's Avatar
i cant remember and i through away my slips. your best bet is some slicks at about 10 psi but depending on your whp you might bog. i was using mt's with 10 psi and i revved it up to 6500 at the line and dropped the clutch and it took off pretty good, 2.02 60'
Old Nov 7, 2003 | 12:22 PM
integraL's Avatar
my michellen tires say 44 psi...i guess thats for longer life?
Old Nov 7, 2003 | 12:48 PM
Clayton's Avatar
H-T Administrator
25 Year Member
Default Re: Street Tire pressure? (integraL)
Are you sure the 44 isn't the max pressure cold? 44 seems pretty high to me.
Clayton
Old Nov 7, 2003 | 07:07 PM
integraL's Avatar
Default Re: Street Tire pressure? (Clayton)
so what should i have it at? yes 44psi is max
Old Nov 7, 2003 | 08:56 PM
sleepN's Avatar
Lowering tire pressure for racing is good for traction. Street tires are not really made to perform with low pressure. It's best to have the tire pressures to the car manufacturers spec for best tire wear and correct alignment angles.
Old Nov 7, 2003 | 09:23 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: (sleepN)
51psi Christ! That's unreal. I run Azenis at 36/38 streets, 18/38 strip, 30/38 course. Try that. If you are on slicks you should be in the 1.XX region no excuses.
Old Nov 7, 2003 | 09:44 PM
V-SPEC 1's Avatar
Default Re: (Mr Milano)
Try 28 psi.
deerman2701
Jan 24, 2012 09:24 AM
CereaLand
Sep 4, 2003 05:37 PM
snake01
Jun 28, 2002 10:09 PM
InfamousRS
Feb 13, 2002 11:41 PM
nicksweetlude
Dec 29, 2001 02:01 PM
