What cams should I get for LS/VTEC setup "I dont want to rev past 8500rpm"
Old Nov 4, 2003 | 08:32 AM
12secEGhatch's Avatar
Default What cams should I get for LS/VTEC setup "I dont want to rev past 8500rpm"
I have LS/VTEC set-up with type-r pistons, shotpeened ls rods, crower head package, type-r cams, port n polish, etc. I dynoed 176whp and 137lbs torque. I am looking for cam that will get me to the 190+ range without having to rev past 8500rpm any suggestions. Motor was assembled by John Brown Racing.
Omar
Kissimmee, Fl.
Old Nov 4, 2003 | 08:41 AM
Irishweird00's Avatar
Banned
Default Re: What cams should I get for LS/VTEC setup "I dont want to rev past 8500rpm" (12secEGhatch)
well, most big lob cams make power up in the rpm range... maybe some toda B's or some EF-1 cams would be better for you.... talk to Rocket on this site... he's from EF-1... he'll help j0o *** out
Old Nov 4, 2003 | 08:43 AM
lsvtec hatch05's Avatar
Default Re: What cams should I get for LS/VTEC setup "I dont want to rev past 8500rpm" (Irishweird00)
anything big is gonna make power gains, why the hell don't you wanna go past 8500? it is hella fun spinning like 9500-10,000
Old Nov 4, 2003 | 08:51 AM
RS_H22's Avatar
The Skunk2 Stage 1's are a pretty decent mild cam and is quite affordable...
They peak at around 8k to 8200 so there really isnt much of a need to rev past 8600 with them...
Just look for a cam that doesnt have a whole lot of duration
Old Nov 4, 2003 | 09:38 AM
-KangaRod-'s Avatar
Default Re: What cams should I get for LS/VTEC setup "I dont want to rev past 8500rpm" (lsvtec hatch05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec hatch05 &raquo;</TD></TR><TR><TD CLASS="quote">anything big is gonna make power gains, why the hell don't you wanna go past 8500? it is hella fun spinning like 9500-10,000</TD></TR></TABLE>
but the bottom end needs to be hella strong.....
Old Nov 4, 2003 | 10:11 AM
sa21199's Avatar
Default Re: What cams should I get for LS/VTEC setup "I dont want to rev past 8500rpm" (RS_H22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RS_H22 &raquo;</TD></TR><TR><TD CLASS="quote">The Skunk2 Stage 1's are a pretty decent mild cam and is quite affordable...
Just look for a cam that doesnt have a whole lot of duration</TD></TR></TABLE>
thats exactly what I was gonna say
Old Nov 4, 2003 | 05:20 PM
VtecDA9's Avatar
Im on the same boat as you, I'm looking to get sk2 stg1 over CTR cams for the simple fact of making power b4 8500.
Is your motor tuned, with your setup, you should be around 200 whp, In fact over if running right. go look at importreview.com and look at the "ls/vtec built the right way." Also check out some dyno charts there too...
Old Nov 4, 2003 | 08:37 PM
ALLMOTOR18's Avatar
Default Re: What cams should I get for LS/VTEC setup "I dont want to rev past 8500rpm" (VtecDA9)
Here is my friends dyno of his ITR motor.. The lower numbers are 2001 ITR cams and the higher one is Skunk2 Stage 1 cams........
JDM ITR block with 11.1 compression... ITR valvetrain with Skunk2 Stage 1 Cams, no porting at all....
These cams are just what you're looking for..
Old Nov 5, 2003 | 02:52 AM
Casey's Avatar
Default Re: What cams should I get for LS/VTEC setup "I dont want to rev past 8500rpm" (ALLMOTOR18)
wow thats a nice gain over itr cams
Ej1SIR
Sep 25, 2009 06:50 AM
B16A1-EF9
Dec 4, 2006 04:58 PM
DsBananas94LS
Nov 27, 2004 09:30 PM
Blind-Fashion
Aug 4, 2004 01:31 AM
VTEC-DA
Jan 2, 2003 07:24 PM
