K20 type R exhuast manifold fits K20a3 (EP3 SI) engine?
Old Nov 3, 2003 | 07:36 PM
A D NOH's Avatar
I really don't know
Community Builder
Default K20 type R exhuast manifold fits K20a3 (EP3 SI) engine?
Just wondering if this works?
And also what is the going rate for a k20 ITR exhuast manifold, thanks
Old Nov 3, 2003 | 07:53 PM
combustion's Avatar
Default Re: K20 type R exhuast manifold fits K20a3 (EP3 SI) engine? (JDM EK9)
no the bolt pattern is different i believe.
Old Nov 3, 2003 | 11:06 PM
03ephatch's Avatar
hhhmmm. ports are different. length is different as well, i'll have to double check on that one. since my bc spec3 ex was made for the dc5-r... hmmm
Old Nov 4, 2003 | 12:38 AM
Gerhard_001's Avatar
Does not fit for the exact same reasons as the RSX type S exhaust manifold does not fit. The flanges on the two exhaust manifolds are different in where the manifold lines up with the bolts on the head.
Old Nov 4, 2003 | 03:39 AM
AussieK24's Avatar
Default Re: K20 type R exhuast manifold fits K20a3 (Gerhard_001)
What about intake manifolds? A2 fit A3????
Old Nov 4, 2003 | 07:34 AM
SIRMcD's Avatar
They are already the same.
Old Nov 4, 2003 | 09:51 AM
B18CXr's Avatar
funny, my A3 exhaust manifold bolts right up to a PRB head......................
Old Nov 4, 2003 | 01:47 PM
Jaminak's Avatar
Default Re: K20 type R exhuast manifold fits K20a3 (B18CXr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote">
funny, my A3 exhaust manifold bolts right up to a PRB head......................</TD></TR></TABLE>
Did you have to do anything more to the manifold to get it to match right?
Old Nov 4, 2003 | 06:29 PM
SilverRSX's Avatar
This may or maynot apply to the Ep3 but to be able to use the manifold on a base RSX requires you either modify your existing exhuast or get an S exhuast . The headbolts are the same. Kinda like on the b-series motors, where you can use a header for a b18c1 on a b18b with some exhuast shortening/extending depending on the car.
Old Nov 4, 2003 | 07:03 PM
A D NOH's Avatar
I really don't know
Community Builder
Default Re: (SilverRSX)
so will it work?
What is the going rate for a DC5 ITR exhuast manifold? and what engines will it fit
Old Nov 5, 2003 | 06:57 AM
B18CXr's Avatar
Default Re: (JDM EK9)
will fit all K series heads, will not fit the EP chassis..
Old Nov 5, 2003 | 08:05 AM
AussieK24's Avatar
Default Re: (B18CXr)
So a K24 intake manifold will fit a K20 head and vica versa????
Edit: Sorry for the hijack hehehe
Old Nov 5, 2003 | 08:37 AM
B18CXr's Avatar
Default Re: (AussieK24)
yes but Y?
remember you'll need the electronics to go with the K24 intake mani if you wish to retain the butterflies............
Old Nov 5, 2003 | 09:27 AM
AussieK24's Avatar
It's cool, I'm fitting a K24 into mine but I gotta source a K20 head from the US (somewhere????) so I wanna make the intake and exhaust manifolds off the K24 head and then fit the K20 head and then I'm good to go
dnxracer
May 30, 2012 06:21 PM
sixfourkiller
Sep 23, 2009 12:04 AM
khummer12
Jul 10, 2009 01:10 PM
E-Money
May 13, 2007 05:42 PM
