Going from stock struts with coil-overs to Tokico Illuminas with coil-overs
Old Nov 3, 2003 | 07:31 PM
willy.wonka's Avatar
Default Going from stock struts with coil-overs to Tokico Illuminas with coil-overs
What should I expect to gain? Is the difference between the two night and day? Or is it rather bleek? My ride right now on stock struts is pretty rough. It isn't bouncy but when I go over pot holes or fucked up areas on the road, my *** hurts.
TIA.
Old Nov 4, 2003 | 04:00 AM
Red94Sedan's Avatar
Default Re: Going from stock struts with coil-overs to Tokico Illuminas with coil-overs (*****.wonka)
The difference will be a total shock from the stock suspension. You will enjoy it
alot. Alot of my frnds have the Tokico Illuminas with either springs or coil-overs
and from that it's a big difference. Also, better handling.
Old Nov 4, 2003 | 04:39 AM
itsJDMyo's Avatar
Default Re: Going from stock struts with coil-overs to Tokico Illuminas with coil-overs (Red94Sedan)
isn't the ride a lot stiffer?
Old Nov 4, 2003 | 04:55 AM
BROOD's Avatar
You will now have struts designed to work with lowered ride heights, they also have adjustability with the stock struts did not have. It will be an improvement over the stock struts for sure...
I'd still steer away from pot holes though..........
Old Nov 4, 2003 | 05:07 AM
Mike_C's Avatar
The ride will bounce less. Stiffer? Yeah if you set them at a high setting, I put my AGXs at full soft in the front and 1 up from that in the rear for street use. I just got back from the track this weekend so they're still on 2f and full hard rear, I absolutely hate it
Old Nov 4, 2003 | 05:27 AM
TwoSaints's Avatar
Default Re: (JMU1337)
I have that exact setup and I love it. I've had it one for like 3 weeks and so far I have kept it on level 5 and the ride is bumpy as hell, but I'm taking turns like they're nothing now. Also if you're running regular tires, watch out for fishtailing in the rain. Ahhh, you'll love it, I DO!!!
ADJinfamy
Suspension & Brakes
Jun 2, 2014 09:18 AM
thecruzs2007@yahoo.com
Aug 12, 2009 09:52 PM
BauleyCivic
Suspension & Brakes
51
Sep 29, 2005 08:36 AM
DA9RsIntegra
Apr 26, 2004 02:51 AM
jmal1919
Mar 13, 2004 02:40 AM
