B20 install into EG question...
Old Nov 3, 2003 | 06:05 PM
Glen Tennis's Avatar
Default B20 swap gurus....
I have done a search and cant find the answer to my question. I am trying to find out how hard it is to do the actual swap. My plan is to put a B20Z into my 92 CX. Just a stock B20Z, nothing too serious. Daily Driver material. My CX used to have a B16 and was stripped by thieves so I need a new motor. How hard? Any snags you guys have run into? Let me know how difficult it was please. Thanks in advance.
Modified by Rockinfunzone at 10:21 PM 11/3/2003
Old Nov 3, 2003 | 06:27 PM
H22EK's Avatar
Default Re: B20 install into EG question... (Rockinfunzone)
Very easy as far as the swap goes, there is nothing special at all about it
Old Nov 3, 2003 | 09:22 PM
Default Re: B20 install into EG question... (H22EK)
bump
Old Nov 4, 2003 | 01:58 AM
Maximus's Avatar
Did the thieves take just your motor or the whole swap? If just the motor then its just a matter of installing the b20 and wiring it up.
Old Nov 4, 2003 | 08:32 AM
ProJectCvic's Avatar
Default Re: B20 swap gurus.... (Rockinfunzone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rockinfunzone &raquo;</TD></TR><TR><TD CLASS="quote">I have done a search and cant find the answer to my question. I am trying to find out how hard it is to do the actual swap. My plan is to put a B20Z into my 92 CX. Just a stock B20Z, nothing too serious. Daily Driver material. My CX used to have a B16 and was stripped by thieves so I need a new motor. How hard? Any snags you guys have run into? Let me know how difficult it was please. Thanks in advance.
Modified by Rockinfunzone at 10:21 PM 11/3/2003</TD></TR></TABLE>
If you install the b16 yourself, the b20 should be easy becauase all b series are similar.
Old Nov 4, 2003 | 10:21 AM
Default Re: B20 swap gurus.... (ProJectCvic)
They took my motor but left the half shafts and didnt mess with anything else I belive.
I had a shop install the B16, this is my first try at intalling a motor myself.
Old Nov 4, 2003 | 01:14 PM
Keeping readin about other people mistake and if you have any machanical experience, i say go for it
B series are piece of pie
Old Nov 4, 2003 | 08:08 PM
Combustion Contraption's Avatar
i did my first b series about a month and a half ago, and if you have any common sense at all, and a decent set of tools, youll be set. its cake...
Old Nov 5, 2003 | 11:23 PM
Default Re: (LsVtec92Hatch)
Coo, I cant wait.
Old Nov 6, 2003 | 12:32 AM
Maximus's Avatar
The mechanics of the swap are tedious like any swap but easy. The wiring on the other hand is a bitch.
Old Nov 6, 2003 | 04:09 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rockinfunzone &raquo;</TD></TR><TR><TD CLASS="quote">My plan is to put a B20Z into my 92 CX. Just a stock B20Z, nothing too serious.</TD></TR></TABLE>
It is a very easy and straight forward swap. The only wiring you will need to do is to convert to a 4 wire O2. This might already be done on the cabin side since you had a B16 in there, but depends on how it was wired it up.
You'll need a B series hydro tranny, LS intake manifold (94-95 LS), and an OBD1 LS ECU to run the motor. You said that the axles were left, so you could reuse those by getting the proper intermediate shaft.
Old Nov 6, 2003 | 07:06 PM
Maximus's Avatar
Default Re: B20 swap gurus.... (VTECVillain)
Check signiture for my intermediate shaft for sale, its packed up and ready to go. I was going to install a b20/vtec into my 94 dx and I bought my intermediate shaft then. Now with my Type R swap installed I have an extra one lying around.
Old Nov 9, 2003 | 03:12 PM
Do I have to use a 94-2000 LS intake manifold or can it be from an older LS? I compared pictures and they are pretty much the same except for small differences. Can I use an older one? Its all LS and I dont think they chanteg it much.
Old Nov 9, 2003 | 05:30 PM
yes you can. The obd1 just a better flow though.
Old Nov 9, 2003 | 07:32 PM
Maximus's Avatar
Just for reference but the LS and CRV heads are the same. Buy a long block and the swap will be a breeze.
Chaoticdopey
12
Jun 26, 2014 04:19 PM
SLPN H
Jul 21, 2011 06:08 PM
g2b2
Mar 13, 2007 03:38 PM
nacho
Dec 12, 2004 03:33 PM
