water from the air conditioner
Old Sep 7, 2001 | 05:27 AM
sidwin's Avatar
New User
Default water from the air conditioner
hey everyone,
I have a 94 ex coupe accord. My passenger side has enough water for a goldfish. I checked the hose that is goes out to the firewall and I thought that was the problem, but the car is still dripping water with the air conditioner on. Does anyone know how to check the evaporator canister? What the hell could be dripping?
Thanks,
Sid
95 TT Supra 423 rwhp
94 Accord EX-coupe leaky!! http://www.sidwin.com
Old Sep 7, 2001 | 05:28 AM
SOHCArchangel's Avatar
Default Re: water from the air conditioner (sidwin)
outside?
water condensation from the cooling process all cars do that, but i ripped out my a/c a while ago, so i dunno
Old Sep 7, 2001 | 06:05 AM
urbanlegend21's Avatar
New User
Default Re: water from the air conditioner (SOHCkordVTEC)
that is all it is..... no problem with the car just the air conditioning just you lines sweating from the outside humidity and dripping on the ground.. most all cars drip on the passenger side
Old Sep 7, 2001 | 02:28 PM
HoNdAeX11's Avatar
New User
you ripped out your a/c! was that hard, i mean you have a good reason to because it will suck power, but was there a lot envolved with that? and what about when you need the defroster because when you run it with the a/c button on it does a hell a lot better in my opinion
Old Sep 7, 2001 | 03:40 PM
BreakStuff's Avatar
New User
Hey sidwin,
You may want to look a little farther than just checking the a/c drain hose, meaning the hose itself may not be clogged, but the drain stem on the evap casing may be blocked, all it takes is one little leaf to bock off the evap drain..
Try taking the drain hose off the casing and stick pen,pencil ( I use the end of a coathanger) in the casing stem and see if any water comes out...
Old Sep 7, 2001 | 07:04 PM
New User
Default Re: water from the air conditioner (BreakStuff)
good suggestion, that was going to be my next post
zoomhonda
Apr 27, 2010 01:21 PM
HondaAccordTdR
Aug 31, 2008 02:51 PM
Revolver123
Honda Civic (2001 - 2005)
Jun 14, 2008 05:01 PM
jbashir
Aug 7, 2003 01:42 PM
sidwin
Sep 7, 2001 03:43 PM
