Official 5lug swap onto EP3: What fits and what doesnt?
Old Nov 3, 2003 | 04:46 PM
migs's Avatar
Default Official 5lug swap onto EP3: What fits and what doesnt?
Please make this a central thread for all the "what fits and what doesnt" instead of "dont waste your money" thread.
If I were to buy FULL DC5R suspension and brakes w/ wheels, will it fit directly on my USDM EP? From what it seems, it seems as if it would fit but a friend of mine told me otherwise?
I do not want to just upgrade to the later style EP 5lug (wanna be), I want to use the RSX/Integra chassis components for better braking and the 17" DC5R wheels.
Old Nov 3, 2003 | 08:04 PM
keithg's Avatar
Default Re: Official 5lug swap onto EP3: What fits and what doesnt? (Migs)
Yes, if you buy the full suspension and brakes from the dc5 it will fit the ep3. I did it to my car 18 months ago and If I remember correctly, the only other part I needed was dc5 tie rod ends for the rack and pinion. Go for the DC5-R parts if you can afford it for the red Brembo front calipers.
Old Nov 4, 2003 | 09:37 AM
Suk02Si's Avatar
Default Re: Official 5lug swap onto EP3: What fits and what doesnt? (keithg)
http://www.k-series.com/tech_d..._CONV
Old Nov 4, 2003 | 09:43 AM
B18CXr's Avatar
I'll sticky this for a few days so as to help reduce reposts in the future...
Old Nov 4, 2003 | 03:30 PM
Aquaman's Avatar
Default Re: Official 5lug swap onto EP3: What fits and what doesnt? (B18CXr)
Why not use the 04 Si's 5-lug? Wouldn't it be cheaper..albeit not being as good as the R's but still.
Old Nov 4, 2003 | 05:40 PM
Steve26's Avatar
Default Re: Official 5lug swap onto EP3: What fits and what doesnt? (Blk02EP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blk02EP &raquo;</TD></TR><TR><TD CLASS="quote">Why not use the 04 Si's 5-lug? Wouldn't it be cheaper..albeit not being as good as the R's but still. </TD></TR></TABLE>
I think you just answered your own question...
Old Nov 5, 2003 | 04:21 PM
JMI's Avatar
JMI
I have them on my EP3.
http://www.ephatch.com/forum/s...16619
To further the info in the above post.
You need the DCR-5 Front sway bar ! The DC5 Hubs insert 15mm ( I belive it's been a while) of positive offest. This increases that track of the car. With 45 offset rims they stick out too much. The DC5-R rims have an offset of 50. I am going to try them on my car this weeked. I still think they will stick out too much. We will see.
Derek of JMI
Old Nov 7, 2003 | 11:45 AM
Saga's Avatar
Default Re: Official 5lug swap onto EP3: What fits and what doesnt? (JMI)
DC5-R rims = +60. That's why +45 rims stick out way too much.
Old Nov 7, 2003 | 04:55 PM
JMI's Avatar
JMI
+ 60 wow I read they were 50. I have two of comming this weekend. If they fit I'l be geting my partner to bring me back a set. Teh two I have curb rash.
Old Nov 8, 2003 | 12:05 PM
RacerDre's Avatar
i converted to 5 lug using base rsx parts but still using the stock si calipers.
by the way i used H&R 15mm Spacer for the DC5R wheels
Old Nov 8, 2003 | 05:21 PM
Civicboy's Avatar
Default Re: (RacerDre)
God I love your EP Makes me really want one.
Old Nov 10, 2003 | 10:59 AM
zer0zer0 TypeR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RacerDre &raquo;</TD></TR><TR><TD CLASS="quote">i converted to 5 lug using base rsx parts but still using the stock si calipers.</TD></TR></TABLE>
so basically the 5 lug was for looks? Cause the stock Si brakes are pretty much crap...
Old Nov 10, 2003 | 12:46 PM
Suk02Si's Avatar
Default Re: (zer0zer0 TypeR)
"Pretty much crap" would be a compliment
Old Nov 10, 2003 | 01:07 PM
RacerDre's Avatar
pretty much for looks. more of the larger quality wheels only come in 5 lug.
Old Nov 10, 2003 | 03:59 PM
Todd00's Avatar
I said I don't want a title!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zer0zer0 TypeR &raquo;</TD></TR><TR><TD CLASS="quote">
so basically the 5 lug was for looks? Cause the stock Si brakes are pretty much crap...</TD></TR></TABLE>
Why are they crap? What is it that you personally do that overwhelms them?
I put Axxis Ultimate pads all the way around on my otherwise 'stock' EP3 brakes and the car stops great.
Old Nov 10, 2003 | 07:21 PM
migs's Avatar
Default Re: (Todd00)
I will be honest, for the most part, I will do this swap for looks only. Another reason is because I want to interchange wheels from my DC2 to my EP3 to my DC2.
Old Nov 11, 2003 | 03:31 PM
zeroryde's Avatar
Default Re: (Migs)
5 lug is stronger too... don't forget u have an extra lug holding ur wheel in
Old Nov 11, 2003 | 10:01 PM
glw's Avatar
glw
Default Re: (zeroryde)
you also have an extra hole or two drilled through the hub on the wheel...
Old Nov 12, 2003 | 05:02 PM
garagespecial
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeroryde &raquo;</TD></TR><TR><TD CLASS="quote">5 lug is stronger too... don't forget u have an extra lug holding ur wheel in</TD></TR></TABLE>
Old Nov 13, 2003 | 04:48 PM
t o m's Avatar
cant forget better brake options
Old Nov 14, 2003 | 03:29 PM
.::miLan's Avatar
Default Re: (INTEGRA TYPE S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by INTEGRA TYPE S &raquo;</TD></TR><TR><TD CLASS="quote">
cant forget better brake options </TD></TR></TABLE>
That's what it would ultimately come down to for me. If I were to do a 5-lug swap, it would be for better/optimal brake combo options. There seems to be a bigger/somewhat better selection for 5-lugs than for 4.
Old Nov 16, 2003 | 07:22 AM
skamal's Avatar
And better brake physics, you have an extra lug to spared the weight of the car stopping.
*where's that Sherlock pic now*
Old Nov 17, 2003 | 12:27 PM
Davanca's Avatar
Default Re: (skamal)
I don't know why honda just didn't make the EP3 5-Lug from the factory. They should have known better than to put 4-Lug on that car. Whats wrong with them?
Old Nov 18, 2003 | 02:58 PM
migs's Avatar
Default Re: (davanca24)
Guys, please keep this on topic. I possibly might do 5 lug swap in the future and I dont need childish responses.
Old Nov 19, 2003 | 09:35 PM
Pdohhh's Avatar
The typer wheels look sweet on that EP...
