B16 rexers...what do you typically launch at?
Old Nov 3, 2003 | 04:20 PM
Hybrid Invasion's Avatar
Default B16 rexers...what do you typically launch at?
This topic is probably kinda exhausted, but I didn't find anything in search. For those of you who have B16 CRX's, what rpm do you typically launch at? I just can't seem to find a happy medium; either I bog or I spin. I'm running on street tires, so I know that's hurting me, but what in the world can I do to improve my launch? Every single race i've lost has been off the line, and it's irritating.
Old Nov 3, 2003 | 04:51 PM
daygo_beanR's Avatar
From: san diego, miami, rosarito mx, rio de janeiro, guangdong
Default Re: B16 rexers...what do you typically launch at? (Hybrid Invasion)
me= 4500rpm with 555s..o yea, lsd tranny
Old Nov 3, 2003 | 04:59 PM
Default Re: B16 rexers...what do you typically launch at? (daygo_******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daygo_****** &raquo;</TD></TR><TR><TD CLASS="quote">me= 4500rpm with 555s..o yea, lsd tranny </TD></TR></TABLE>do you hold your rpms at 4500 and then let the clutch out gradually when you go, or do you basically just dump the clutch the second you go?
Old Nov 3, 2003 | 05:11 PM
Redline130's Avatar
I launch at around 7800 to 8000 rpm. I just hold that rpm and dump the clutch. 60ft times are usually mid to high 1.8's. I use M&H slicks and I don't have a LSD. The two things that made the biggest difference in my launches were the slicks, stiffening the rear suspension, and the Z10 crossmember. If you are going to stay with street tires, I'd say lower the tire pressure to about 20psi and try and find a rpm range in which you spin your tires the least. Maybe start a 3500 rpm and work your way up or down. Launching in VTEC will definitely lead to wheel spin on street tires.
Old Nov 3, 2003 | 05:23 PM
Default Re: B16 rexers...what do you typically launch at? (Redline130)
well, i'm in the middle of getting a set of Group N's with either 195 or 205 series Falken Azenis, so i'm hoping that will help my traction woes a little bit. I guess my question was whether or not you hold your rpms and then when the lights turns green dump the clutch, or if you kinda feather the clutch out on the start. You definitely get good results from holding at whatever rpm you launch at and dumping the clutch? I'm just trying to learn the best technique, and rather than act like a hardass and pretend I know how to do it right, i'll just ask.
Old Nov 3, 2003 | 05:34 PM
k20pinay's Avatar
i'm launching at 8000 and shifting at 8700. when coming off the line at palmdale i bog down a little because i don't have enough torque to keep the tires spinning...one down fall to a b16. if you're running on street tires, try launching at 3000 to 4000 and then go from there. good luck.
Old Nov 3, 2003 | 05:36 PM
Redline130's Avatar
For me I just hold the rpms and dump the clutch on the last yellow light before the green. I'm going to be installing a 2-step to help me be more consistent on my launches. At least I'll be leaving at the exact same rpm every time. Getting your launch down just takes practice. Every car is different and every driver is different. The next time your at the track, try different methods and see which works best, be it dumping the clutch or feathering it out. For me, it's more fun to just dump it
Old Nov 3, 2003 | 05:42 PM
kill bill's Avatar
on street tires and an open diff, i used to launch mine at 4k on the streets...just dump the clutch, and control spin with the gas, not the clutch.
Default Re: B16 rexers...what do you typically launch at? (b16pinay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16pinay &raquo;</TD></TR><TR><TD CLASS="quote">i'm launching at 8000 and shifting at 8700. when coming off the line at palmdale i bog down a little because i don't have enough torque to keep the tires spinning...one down fall to a b16. if you're running on street tires, try launching at 3000 to 4000 and then go from there. good luck. </TD></TR></TABLE>well i definitely don't bog, i do nothing but spin. I'll try dumping the clutch at about 3500 and see if i still spin.
Old Nov 3, 2003 | 06:03 PM
kill bill's Avatar
in doing that, youll need to let off the gas a bit, to control the wheel spin...spinning tires is ok as long as your going forward
Old Nov 3, 2003 | 06:04 PM
k20pinay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid Invasion &raquo;</TD></TR><TR><TD CLASS="quote">well i definitely don't bog, i do nothing but spin. I'll try dumping the clutch at about 3500 and see if i still spin.</TD></TR></TABLE>
what is your tire pressure? sounds like you aren't hooking up, try running a lower tire pressure.
Old Nov 3, 2003 | 06:08 PM
what is your tire pressure? sounds like you aren't hooking up, try running a lower tire pressure. </TD></TR></TABLE>well my tire pressure is supposed to be 40psi... lemmie give u an idea as to what i have. I have stock si rims, so i have 195/60/14's on em....since the tires are supposed to be filled at 40psi, i usually drop the pressure to 30. I still spin like a bitch though....think I should go lower?
Old Nov 3, 2003 | 07:20 PM
k20pinay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid Invasion &raquo;</TD></TR><TR><TD CLASS="quote">well my tire pressure is supposed to be 40psi... lemmie give u an idea as to what i have. I have stock si rims, so i have 195/60/14's on em....since the tires are supposed to be filled at 40psi, i usually drop the pressure to 30. I still spin like a bitch though....think I should go lower?</TD></TR></TABLE>
well...keep in mind you are on street tires...honestly, you may want to invest in some cheater slicks. trust me, it will make a huge difference! i went from a 9.2 to a 8.9 on cheaters.
Old Nov 3, 2003 | 07:39 PM
SadisticRacing's Avatar
I used to just dump the clutch from 4200rpm and had my tires at 24psi.
IT'S ME DAVID
May 29, 2007 05:36 PM
92-Teal-Hatch-B16
Sep 8, 2006 03:26 PM
04falcon
Aug 26, 2005 08:02 PM
verticle
Oct 2, 2004 11:38 PM
TYspeK EH2
Jul 7, 2003 02:16 AM
