If you can answer this with good meaning I praise you.
Old Nov 3, 2003 | 02:08 PM
mntuner2's Avatar
Default If you can answer this with good meaning I praise you.
My left front axle needs to be replaced. Here is my setup/ options:
88 ed9 chassis
88 dx manual 5 speed transmission
93 d16z6 engine w/ pm6 control.
options:
stock axle (BORING)
used axle (even more boring)
d16 integra axles w/ half-shaft (mmm I like the sound of that)
The doozey is this: Are the integra axles able to couple the differential/trans housing and half-shaft mount to block? I honestly think this is possible. I have yet to get a straight answer from anyone. If no one sheds light on my proposition I am going to go to the junkyard this weekend. And if you do, well there just may be a cookie in it for ya'!
Thanks in advance for the insight.
Even if you don't know, ideas, comments, concerns and corrections are appreciated.
Old Nov 3, 2003 | 03:23 PM
Disco Stu's Avatar
Default Re: If you can answer this with good meaning I praise you. (mntuner2)
Are you putting down a good amount of power? If not, Pep Boys has an excellent array of axels for you to choose from. Honestly, I don't know if it will work, but even if it does, and you get your parts from a junkyard, that's still gonna be used parts. So why not just get a cheap-o replacement?
Oh, and don't knock Pep Boys, their car people. Good luck!
Old Nov 3, 2003 | 03:37 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
the D16 Integra axles will fit, I have done it.
the only question is whether ot not the D16Z6 block has the holes drilled and tapped in the right location for the half shaft.
I know for a fact that the D16A6 does have the holes threaded for the half shaft and installation is a direct bolt on.
So get under the car and check to see if you have three threaded holes with nothing on them. I have a D16Y7 and it didn't have them.
Old Nov 3, 2003 | 04:39 PM
mntuner2's Avatar
Default Re: If you can answer this with good meaning I praise you. (The new Spaceballs)
Thank you brother. I thought so. I am good with the tap and die so I shouldn't run into any problems. I am soo excited! I am getting my chip burning setup within the month! Yippeee. LSD and struts and I will have one kick-*** beater!
Old Nov 3, 2003 | 05:47 PM
kid-honda's Avatar
I am almost positive only the A6 has the holes already tapped and the rest need to be tapped. If this works that would be sweet.
Old Nov 4, 2003 | 04:49 PM
mntuner2's Avatar
Default Re: (kid-honda)
Haven't looked yet. It has been very busy at my work lately. I called the junkyard today. $30 for the pair of 88 integra axles and $30 for the half-shaft.
VTECROAR96typeR
Suspension & Brakes
Feb 21, 2009 08:27 AM
EJ2 LSVTEC
22
Sep 25, 2007 08:47 AM
SiRay13
Jun 26, 2006 01:59 PM
honda06si
Aug 15, 2004 10:23 AM
turbohf
14
May 22, 2002 10:02 PM
