d16z6 / minime
Old Nov 3, 2003 | 06:59 AM
Limited S.L.I.P.'s Avatar
Default d16z6 / minime
I currently have a 1.6 EX, with a d16z6 head and working vtec (minime). I am picking up a d16z6 long block on Weds. and I am wondering if I will experience and power gains/losses. I will do it regardless for reliability reasons.
My current setup is as follows:
Stock d16a6 airbox, IM, bottom end; Kamakazi header, rebent apexi exhaust.
I will be keeping everything as is EXCEPT the longblock. It seems to me it will be the same or similar in performance.
Any input?
Old Nov 3, 2003 | 08:05 AM
anybody have some words of wisdom? should i try posting elsewhere?
Old Nov 3, 2003 | 08:07 AM
USDM 4G VTEC's Avatar
Default Re: (Limited S.L.I.P.)
IMO i love more the full longblock Z6 over a mini me. thats just me...
i did 121 wheel hp on my Z6 and my mini me did 111whp and 118 whp with the comp cam before spun a bearing..
on my Z6 now with cam its way stronger than the previous counterpaths
Old Nov 3, 2003 | 08:19 AM
91civicDXdude's Avatar
the d16a6 block with d16z6 head will give you almost 10:1 compression (9.9:1 to be exact).
the d16z6 is 9.2:1 with the same bore and stroke. I would think that if both engines are in the same condition, the d16a6 minime will give more power... the dude with the mini above forgot to mention that his was a 1.5L, which im guessing the block was in pretty bad shape seeing as how he spun a bearing... the 1.5L d15 mini me has a 10.1:1 compression ratio.
on a side note, im currently running a d15 hybrid non VTEC (d15b8 block, D16y7 head, D16A6 intake) and it smokes pretty bad, BUT i rev that ******* to 7200 ever day and its had no problems whatsoever..
Old Nov 3, 2003 | 08:42 AM
ok- thanks guys.. I'm not expecting much of diff. but I'm hoping not to have any stupid little problems. thanks guys!
blkcoupe94
May 30, 2005 11:19 AM
Generic User Name
Jan 4, 2005 06:03 PM
Kato7997
Mar 5, 2003 01:51 PM
