!HELP- 1994 Accord (TEC DIST+ EX. COIL) wire locations for Mallory HyFire VIA install
I currnetly have a 1994 Accord LX 2.2L (F22) with the TEC Distributor and external TEC coil. I was hopeing to be able to install the ignition to the stock coil (and when I have further bolt ons I will buy the wire for my accel coil 140001). However right now I am trying to figure out which wires to clip or tap into. By the wiring diagram I am guessing it shows to tap the wire by splicing and keeping the wires connection the same but having an additional plug to use the CD igntion on that line as well.
There are 2 Wiring harnesses next to the distributor one with 8 wires coming out of it and another with 2 slightly larger gauge wires coming out of it.
I was guessing and wondering if the 2 wire connector harness is the wire set i should be tapping into or cutting...(black wire yellow stripe and blue wire)
I guessed the blue wire to be the 12V+ Ignition key i should be triggering the red wire to and the Blac/Yellow the tach wire I should be tapping into. (Please correct me if i did this wrong...)
Can someone give me a layout to work with here and plug this in... she doesnt purr right now
Basic blitz air filter replacement on stock air line & resonator.
APC 9.3mm Silicon/Kevlar spark wires
OBX Iridium Spark Plugs
*Accel Coil 140001 (but I want to know how to hard wire the stock TEC external coil instead)...
The tec Coil has 3 wires
I think it is 2 Yellow's and a green...
ELP !
...and thanks!
... Basic blitz air filter replacement on stock air line & resonator.
ELP !...and thanks!
DannyBoy310
Apr 3, 2012 07:17 PM
