Colder or hotter plugs for a fully built n/a set up?
Old Nov 2, 2003 | 09:25 PM
itr817's Avatar
Default Colder or hotter plugs for a fully built n/a set up?
Should i go with a colder plug or a hotter plug for an n/a set up? Please let me know thanks.
Old Nov 2, 2003 | 09:31 PM
VtecDA9's Avatar
Default Re: Colder or hotter plugs for a fully built n/a set up? (itr817)
Give us ur setup... usually colder plugs for a a high compression setup - help eliminate detonation, but like i said it varies depending on your setup.
Old Nov 3, 2003 | 08:00 AM
TEAMGENDAI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr817 &raquo;</TD></TR><TR><TD CLASS="quote">Should i go with a colder plug or a hotter plug for an n/a set up? Please let me know thanks.</TD></TR></TABLE>
hotter or colder than what?? im going to assume you meant hotter or colder than stock. colder, run a heat range of 8 or 9 your stock plug should be 5 or 6 depending on what engine. anyway good luck!!
garyc17
May 11, 2007 09:51 AM
Devo94ac
Nov 2, 2005 08:53 AM
X2BOARD
Jul 15, 2004 11:37 AM
gassinit
Dec 12, 2003 05:48 PM
TeamTooQuick
Aug 9, 2003 07:23 PM
